Depends what sort of budget you've got for the system...
If you're looking at spending under $1k, perhaps JB or Ebay.
If you're looking at spending up to $2k, then you can venture into the world of specialists with quality gear :)
Whats your budget and we can recommend some stores...
Well its not a show car, and i dont drive around the streets with my music booming.
Car is a 3dr hatch and sort of semi collectable so not looking to cut up door trims etc as they are all in immac 1987 condition
What I have pieced together so far is:
Deck:
Pioneer DEH-8350SD
http://www.pioneer.com.au/au/products/22/121/61/DEH-8350SD/index.html
Amps:
Either a good quality 5 channel L5.1110 - http://www.soundstream.com/los/lil-wonder_amp.htm
Or a 4 channel Sony Explode GTX6040 for speakers http://www.sony.com.au/product/xm-gtx6040 : and Soundstream STL2.350 2 channel bridged for subs
Speakers:
Front - In the front plastic dash it takes 4" speakers. I can remove the original lower sill kick panel and put in a custom pod to take 6.5" splits. I am thinking about putting speakers in the dash and lower kick panel, but dash will probably be of no value and better putting the money into a better quality split.
Rear - 6x9s in a new custom parcel shelf as I dont want to cut up the original one. I also doubt the original hatch would be suitable for big heavy speakers in them.
Subs - I am guessing a single 12" in a good box that will go behind the split fold hatch seats.
I have not decided on brands of speakers and frankly dont care about brands of speakers. The only thing I am picky on is the deck and happy with the Pioneer deck I have found
Last time I played with stereos was 10 years ago and have not had kept pace of things. I used to run Polk 6x9s and splits, Kicker subs and Rockford amps.
Not sure I want to go to that expense again and it seems that single 12s give pretty good sound these days. So rather then two cheaper 12" subs I suspect I would get better sound and still work out cheaper to get a better quality single 12" with plenty of nice clean power. Seems Sony and MB Quartz have reasonable priced splits at around $150 and a pair of 6x9s for the same price. Subs have me stumped, so much has changed in sub technology the past ten years :(
So budget isnt huge, but neither are my needs. Its a rattly old 80s car so need a stereo to hush up the rattles
TL:DR
But forget about the rears or a 5 channel amount.
Spend your money on a decent quality 2 channel amp to power the front splits.. Monoblock for the sub. And run your existing rear speakers off the headunit.
That's the basic SQ setup.
I need something in the rear, sun affected 1987 paper cone speakers dont sound that great, even if only being powered off the deck :)
Fair enough, forget about the rears alltogether unless you frequently carry rear passengers
fark off ya kent......all you need is a loud exhaust.....or are you looking for something to mask the dash rattles?Coz the exhaust also works for that....thats why you get the impression my car drives so well :thumbsup:
Well weld me up a titanium exhaust like on your car. By the way I am calling your car Beelzebub :)
Blah, blah..its a hatch not a coupe/sedan. So like a 180SX a lot of noise etc comes from the rear and echos around off the glass and the old std shelf. So will be installing a new shelf and sound deadening so may as well throw some speakers back there to try and dull the noise...and with an old school, heavily compromised front...I dont have any good locations for speakers, or even doors thick enough to take a decent sized magnet etc. So need the rear to help as much as it can
Others, thanks for the tips. Hopefully car will have rego in the next 2 weeks and will get something sorted and speak with Freeway Car Audio.
Freeway car audio is a good place to visit. I've gotten a few things from their.
Phatt Audio Concepts is known as one of the le' premier places to get your audio equipment installed. They can also source audio equipment.
They also had their own TV show called 'Nsayne TV on Car Audio' and handle projects such as 'Alpine's own demo car'.
Check out some of their Car Audio episodes and you may want to go with 'Phatt Audio Concepts'. :D
Jaycar also sell speakers and subs. All that have won many awards when compared against name brand equipment.
Any audio shop will try and sell you pioneer & alpine gear and judging from your requests, you are after a basic set. For the same money as basic brand name kit you can get a decent setup from Jaycar.
Good luck
I am a bit nervous about handing the car over to people. New car itis and the first person to have touched it and charged me good money has hacked it up a little. I can do that with the best of them and it wont cost me anything.
So , figure this will be a back to my youth thing and will do it all myself. Thanks for your advice though. I still need to buy the speakers and subs so may swing by a few places this weekend and listen to a few brands/models
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
