Depends what sort of budget you've got for the system...
If you're looking at spending under $1k, perhaps JB or Ebay.
If you're looking at spending up to $2k, then you can venture into the world of specialists with quality gear :)
Whats your budget and we can recommend some stores...
Well its not a show car, and i dont drive around the streets with my music booming.
Car is a 3dr hatch and sort of semi collectable so not looking to cut up door trims etc as they are all in immac 1987 condition
What I have pieced together so far is:
Deck:
Pioneer DEH-8350SD
http://www.pioneer.com.au/au/products/22/121/61/DEH-8350SD/index.html
Amps:
Either a good quality 5 channel L5.1110 - http://www.soundstream.com/los/lil-wonder_amp.htm
Or a 4 channel Sony Explode GTX6040 for speakers http://www.sony.com.au/product/xm-gtx6040 : and Soundstream STL2.350 2 channel bridged for subs
Speakers:
Front - In the front plastic dash it takes 4" speakers. I can remove the original lower sill kick panel and put in a custom pod to take 6.5" splits. I am thinking about putting speakers in the dash and lower kick panel, but dash will probably be of no value and better putting the money into a better quality split.
Rear - 6x9s in a new custom parcel shelf as I dont want to cut up the original one. I also doubt the original hatch would be suitable for big heavy speakers in them.
Subs - I am guessing a single 12" in a good box that will go behind the split fold hatch seats.
I have not decided on brands of speakers and frankly dont care about brands of speakers. The only thing I am picky on is the deck and happy with the Pioneer deck I have found
Last time I played with stereos was 10 years ago and have not had kept pace of things. I used to run Polk 6x9s and splits, Kicker subs and Rockford amps.
Not sure I want to go to that expense again and it seems that single 12s give pretty good sound these days. So rather then two cheaper 12" subs I suspect I would get better sound and still work out cheaper to get a better quality single 12" with plenty of nice clean power. Seems Sony and MB Quartz have reasonable priced splits at around $150 and a pair of 6x9s for the same price. Subs have me stumped, so much has changed in sub technology the past ten years :(
So budget isnt huge, but neither are my needs. Its a rattly old 80s car so need a stereo to hush up the rattles
TL:DR
But forget about the rears or a 5 channel amount.
Spend your money on a decent quality 2 channel amp to power the front splits.. Monoblock for the sub. And run your existing rear speakers off the headunit.
That's the basic SQ setup.
I need something in the rear, sun affected 1987 paper cone speakers dont sound that great, even if only being powered off the deck :)
Fair enough, forget about the rears alltogether unless you frequently carry rear passengers
fark off ya kent......all you need is a loud exhaust.....or are you looking for something to mask the dash rattles?Coz the exhaust also works for that....thats why you get the impression my car drives so well :thumbsup:
Well weld me up a titanium exhaust like on your car. By the way I am calling your car Beelzebub :)
Blah, blah..its a hatch not a coupe/sedan. So like a 180SX a lot of noise etc comes from the rear and echos around off the glass and the old std shelf. So will be installing a new shelf and sound deadening so may as well throw some speakers back there to try and dull the noise...and with an old school, heavily compromised front...I dont have any good locations for speakers, or even doors thick enough to take a decent sized magnet etc. So need the rear to help as much as it can
Others, thanks for the tips. Hopefully car will have rego in the next 2 weeks and will get something sorted and speak with Freeway Car Audio.
Freeway car audio is a good place to visit. I've gotten a few things from their.
Phatt Audio Concepts is known as one of the le' premier places to get your audio equipment installed. They can also source audio equipment.
They also had their own TV show called 'Nsayne TV on Car Audio' and handle projects such as 'Alpine's own demo car'.
Check out some of their Car Audio episodes and you may want to go with 'Phatt Audio Concepts'. :D
Jaycar also sell speakers and subs. All that have won many awards when compared against name brand equipment.
Any audio shop will try and sell you pioneer & alpine gear and judging from your requests, you are after a basic set. For the same money as basic brand name kit you can get a decent setup from Jaycar.
Good luck
I am a bit nervous about handing the car over to people. New car itis and the first person to have touched it and charged me good money has hacked it up a little. I can do that with the best of them and it wont cost me anything.
So , figure this will be a back to my youth thing and will do it all myself. Thanks for your advice though. I still need to buy the speakers and subs so may swing by a few places this weekend and listen to a few brands/models
