Another Person w/GTR moving to Brisbane...
CalaisT3RBO
 Share
Hi,
I am moving to Brisbane on the 16th of May coming from Townsville.
I am keen to get into some of the cruises you guys organise.
I don't get a chance to see many skylines up here will be interesting seeing some other similar GTR's/GTSt's.
I am sending my car down first to Gavin Woods as it needs a couple things fixed that I don't want done in Townsville. Hopefully I can organise to have it ready close to the time I arrive.
Living - Clayfield
Working - Southbank
  • Replies 46
Nice 33's!! I will have to get a better look at one of the cruises, if I can find my way to the starting point. I got a copy of the Brisbane/Gold Coast UBD which has been heaps of help so far. 7 job interviews in one day.
Theres only 3 R32 GTR's in Townsville. More ppl seem to like the R33 shape than the R32 shape.
My name is Jonathan as well.
Does anyone work in Urban Civil Design in Brisbane? (probably not)
Thanks. Being a Engineering Surveyor, I have more to do with the construction side of things (mainly sub-divisions), not so much design. Being from Townsville, ever come across a John Kuskopf? He has a small architect firm there.
Another GTR leaving us, soon there wont be any left ! Hamish with the white R33 GTR is getting rid of his to and i have just sold mine so that only leaves gary and aaron in the R32's and the doctor with his R33 . I think we need more GTR's up here to combat the WRX plague!
welcome jonathan. Looking foward to meeting you. I don't know about your choice of suburb to live in though. :) move to toowong/ indroopilly/ Auchenflower area. That's where most of team brisbane resides. Well, everyone that matters. :D
rock on. :headbang:
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
