New Jaguar XKR-S makes 550 ponies at the crank.:yes:
Honestly what is the point if your RB25 - despite tons of work - is going to get you toasted by an exec in his flappy paddle luxo-barge on his way to work?:/
Troll harder, oh and IBTL
https://www.sau.com.au/forums/topic/387121-blown-v8s/#findComment-6173481
Yeah i bet it weighs less then a skyline and is cheaper............
Just go buy one and spend your time driving it rather than posting pointless threads
IBTL
https://www.sau.com.au/forums/topic/387121-blown-v8s/#findComment-6173577
If i'm not mistaken just doing some quick research around the net and it is looking to have a 1/4 mile of 12.5 whereas compared to stock R33 from factory ran about 14.4 which yeah I am sure a few mods will get you into the bracket with the Jag or the GTR boys will be right next to with only very few mods (32 GTR 1/4 mile time 13 seconds). Starting at $85 000USD I think the money would be better spent on a skyline which purchase cost plus the left over from the amount you spend on the Jag you would have not only a quicker but a sexier car.
https://www.sau.com.au/forums/topic/387121-blown-v8s/#findComment-6174008
Hook,line and sinker
https://www.sau.com.au/forums/topic/387121-blown-v8s/#findComment-6174165
New ford coyote 5.0l comes supercharged in the FG GT model. 335kw. Some tuner down south has added an intercooler, smaller pulley on the supercharger for more boost and has cranked out 500kw atw. Very cool motor, pity it comes in such a sack of a car. I'm waiting for someone to put one in a GT40 kit car or something, that would be awesome :cheers:
https://www.sau.com.au/forums/topic/387121-blown-v8s/#findComment-6174530
So I hear that the Bugatti Veyron produces 1000hp from an 8 litre V16 and does over 400kph. So what is the point of having an RB25 if you are just going to get blown away by Bernie Ecclestone on his way to sleep with his super model girlfriend???
https://www.sau.com.au/forums/topic/387121-blown-v8s/#findComment-6174919
:rofl2:
Lock the thread, we have a winner! It's officially all down hill from here.
https://www.sau.com.au/forums/topic/387121-blown-v8s/#findComment-6174938
Isnt it a W16? Lol
https://www.sau.com.au/forums/topic/387121-blown-v8s/#findComment-6175333
:rofl2:
You forgot there is the upgraded version (Veryon SS) with 1200hp & top speed of 420+km/h...
EDIT: Actually screw the Veryon (& the upgraded version of it) I want a German Lepord 2 tank instead.
Edited by Mayuri Krab
https://www.sau.com.au/forums/topic/387121-blown-v8s/#findComment-6175456
Yeah, a leopard 2 would totally dominate should war break out tomorrow, just another reason not to own the RB25!!!
https://www.sau.com.au/forums/topic/387121-blown-v8s/#findComment-6175595
As top gear has demonstrated with their Maurder review having an armored military vehicle as a daily driver has several benefits.
I no longer have to give a crap about soccer mum's in their 4x4s changing into my lane without looking or some douche tailgating or if you find yourself parked in by some moron who can't park straight.
More reasons not to bother with Skylines anymore...
https://www.sau.com.au/forums/topic/387121-blown-v8s/#findComment-6178883
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
