Engine swap? Many of them came factory with the 1JZ...
those with ma70s are a pain to swap. fuel pump ecu, different engine mounts.
the stuff some guy who bought parts off my soarer for an engine swap told me, made me scared of ma70s.
im loving the old mk3 supra's these days with the ijzgte engine swap.
nice and old school.
anyone know which ones are eligible for importing, what are they worth for a good example and which ones are the the most sought after?
yes, JZA70 = 1JZ
MA71 = 7M-GTE
there is more to swapping than what Alvin said too, subframes are different + 11ty other things!
also, be cool like me and get the "R" model
As for most sought after, that would be the MA71 Turbo "A", 500 made, all black with brown leather etc, bigger turbo, bigger throttle body, tougher bottom end, they were the Group A homoligation model.
as for how much, if you have to ask you can't afford
That's right, I'm thinking Australian delivery ones,
Or did aus delivered ones come with the 1jzgte also?
Might have to rephrase that to a 2jzgte conversion :)
What 86-92 supras are eligable to import to aust and are they expensive?
There are only 9 mk3's for sale they are all 7m motors and 8 of them are autos
  • 4 months later...
  • 9 months later...
Congratulations Kristian on the pristine R32 GTR V-Spec II that has just been picked up by SAUer Chris a few minutes ago!
34,215Km and it's like new!
Full Jap history, no scratches, no sag or wear marks on driver's seat, engine bay looks like new, no seepage, no rust. It's a gem!
  • Like 1
  • 1 month later...
I think it is a combination of a few factors;
- exceptional condition (grade 4.5/4) low mileage cars, under 50000 km, with documented history coming up at Auction and
- the increased demand due to the good exchange rate
I think demand usually reduces a bit and then stabilises when the exchange rate reduces to more sustainable levels. I think we are going through that stabilizing phase. The yen has gone from 105 to around 90 in a matter of weeks.
That black 93 GTR would have been around $38k landed and complied. I agree Chris that is very much VSpec money.
I await Chef's comments.
Tony.
Some of it was certainly exchange rate movement, but also it depends on how much shaken a car has left on it - a car with little or no shaken will drop for a far cheaper price than one with plenty left.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
