Hi guys
Ive just installed my boost controller.
I took it for a spin, and everything *seems* a lot faster.
However, when I go to calibrate it through learning mode, it says that my stock boost level is actually 0.64 bar ? And it doesnt seem to want to boost over 0.7 bar, even When i adjust the EBC to 1.1 bar
Now im not sure that ive connected it correctly
The HKS EVC 4 has 3 lines. One of the lines ive connected to the stock boost sensor right up the back where the black box is, off the line coming off the plenum. As per this photo here
Now, the other two lines off the EVC are meant to go to the actuator, and the other to the line between the turbo and the intercooler (or something like that). What ive done is disconnect the stock boost solenoid, and connect up the EVC in place of it. ie one line goes to the wastegate actuator, the other to the line (i think its the BOV return line ?)
As per this pic
url]
Now Its not adjusting the boost properly, and I have no idea whats wrong ?
I think ive connected it up wrong.
If anyone can post pics/tell me where I should hook up the hoses to, it would be much appreciated.
Cheers
Tom
Definately looks wrong.
You need the pressure signal coming off the plenum which looks right and one hose running to the actuator and one running to the nipple on the inlet pipe (or nipple on the front of the turbo if you have one) where you have the tee. The tee you have on the inlet pipe doesn't look right to me because you need the run the ebc as a closed circuit if that makes sense.
I think the pressure signal is fine, because it goes to the map sensor up the back.
Must I have one hose connected directly to the wastegate actuator, and the other directly into the nipple off the intercooler pipe going to the turbo, thus getting rid of the factory t-piece ?
Cheers guys
Want more boost :)
Tom
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
