Firstly I apologies if this has been covered but either my search function sucks balls or I just can't find anything on the topic?
Ok so my exhaust is a 3" turbo back job but has a custom screamer pipe and a blocked bov for dose
Neither of these things appeal to me
The car has a td05 turbo gtr injectors FMIC and a few other goodies making about 210rwkw at 1bar
The reason I say this is I have 2 questions
Will a stock bov set up either still blocked or plumbed in properly be ok on these boost levels? am I going to loose any power or have more lag or response yadayada,
Looking for a slightly more legal and city friendly sound. I actually don't mind the flutter but yea anyway.
And the other question is what's the best way to plumb both of these things in properly? I know the screamer needs to enter the exhaust system before the cat.
The screamer makes sence to me but I'm not even sure if my blocked bov is a stock unit? Pick below.
Sorry I will also add that I have a limited understanding of the pipe work, how much would a shop slug me without being dicks to remove the screamer pipe and plumb it in?
Thanks in advance for the help and sorry if theirs a million threads already existing.
https://www.sau.com.au/forums/topic/387165-chasing-that-stock-sound/
  • Replies 75
Posted Images
Stock BOV it is . Just use some hose of that size, or source the original hard pipe from a wreck to connect the BOV outlet back to the turbo inlet. Depending on what needs to be done to your turbo inlet to hook that up, this should cost from not a lot to not a lot more.
Exhaust shop should be able to connect the screamer back into the dump at the bottom bend for not a lot. Almost beer money.
Oh, by the way, the stock BOV is the best thing to have on the car for response. And it will be perfectly fine at 1 bar boost.
Edited by GTSBoy
That is the stock BOV, they just whacked a cup over the end to seal it off. Take that off and get that line plumbed infront of your turbo, in your intake pipe. What ECU do you have btw? Do you have an AFM?
I would leave the BOV and get rid of the screamer. That one will get you into big shit.
you can buy a JJR bellmouth dump pipe for $180 which will fix your screamer problem, id rather do that than plumb in the screamer... the bellmouth works best on a stock sort of setup
reconnect the stock bov as its just capped off. buy the stock hoses and pipes from a wrecker. stock bov good to over 20psi no worries (1.5 bar)
Ok I'm going to fly my noob flag a little bit.
I buy the stock solid hose and that goes from my bov to.... Is their another blocked off hose point somewhere?
Also a new bellmouth dump pipe what size are they? Do I need a larger one?
can post a pic of the intake/turbo side of engine, as you say it has a TD05 so the piping may have been changed, if the stock intake pipe is still in place then there will be a port to plumb it back into.
if the TD05 turbo has the standard T25 flange setup them just buy the dump pipe as stated already, pic of screamer from turbo would help with advise aswell
agreed i forgot to take notice that you have a TD05, you may need to retain the custom dump unless your TD05 has the standard sort of dump pipe pattern.
please take a photo of your turbo and plumbing on that side and post.
Is that screamer just pressed into the WG outlet? Jeeezus Christ!
The dump and screamer are nasty enough that I would replace them rather than keep them. But yes, as above, it could just be joined back in and it would work*.
*by work I mean just as well as it does now, but without the shitful noise.
