Had some problems with leaking water hoses, long story short i want to get rid of some hoses.
1) first i need to know what the part circled in red is/does and if i can bypass it
2) secondly the hose that goes into it is T'd off one of the heater hoses and then ends by being T'd back into the other heater hose(traced in blue), if i can bypass the part circled in red and delete all of the hard pipe that runs along the block do i still need a hose going between both heater hoses?
Any help would be appreciated
https://www.sau.com.au/forums/topic/387184-what-is-this-part/
not the answers i wanted to hear but i can work with, i have a sandwich plate coming already so i could run an external cooler or i could still run new main hoses with a couple of T's to allow me to delete the hard pipe and make things simpler.
Thanks for the info guys.
Mate its actually called a "Heat exchanger" its function is to get the oil and water temps as close to one another as possible. The Nismo oil cooler kit actually gets rid of the part altogether,but it also has a thermostat that by passes the oil cooler until oil gets hot enuff.. if you run both an oil cooletr and H-E sometimes the car runs too cold or takes forever to warm up. Most modern race cars (circuit) run H-E not to runn cooler but to run even water/oil temps. Dont know if that helps with your decision but if ur running an oil cooler and wont be doing much track work just take notice of ur oil n water temps and then decide whats best. ideally u want oil and water around 80-90deg.
I want to do a couple of track days but in general its just a street car, with that info tho I think I will forget about getting an external cooler for now and just use a couple of T's and still run the HE.
80-90 degrees? My car normally sits at low 70's and high 70's when I give it some stick
all the more reason to keep the standard oil cooler. if your coolant temps are low you can safely assume your oil temps should be pretty good. mynes fairly similar to yours (low 70s) and i run slightly thinner oil than everyone else because it never gets hot enough
The standard ones are in a prick of a position, I know once replaced they will last forever but also there molded so would have to get them from Nissan $$$, the hard pipe is corroded so I want to get rid of that too.
Well then you need the tools, materials and a bit of imagination.
You could relocate it with bends and hose.
Try a plumbing shop. Copper water pipe is rated to very high pressure.
There is heaps of stuff you can do with copper pipe and hundreds of different fittings for it.
Get it all worked out and get someone with an oxy to solder it for you.
Then you dont need $$$ nissan hoses HOWEVER.... do the maths you will probably find all the messing around gets expensive too.
Deleting it with custom bits is by far the cheapest option
Major hint when doing this kinda stuff
Keep it simple.
Then you dont need $$ nissan hoses HOWEVER.... do the maths you will probably find all the messing around gets expensive too.
Keep it simple.
I am keeping it simple, you just made it more complicated than the factory setup, there will be no custom copper or welding or a plumbers shop, the whole idea is to replace items that are unique to this setup and therefore need to be ordered through nissan with off the shelf items that can be bought at any parts store.
The plan is simply to run one hose from the front of the block to the heater (either join up to the existing hose or one off the shelf item) with a T piece which when put in the right place in the hose would then just require one straight hose to supply water to the heat exchanger, if pressure is a problem i know you can get a long wire coil thing (dont know its name or if it even has one) that goes on the out side of the hose and stops the hose from expanding too much, that solution on its own deletes the hard line that runs along the block and brings it out from the block for east access if i ever need to get to it again.
Now that i think of it if i did go the copper line route then it would simply be one straight piece of copper pipe with a smaller T piece welded 2/3's of the way along for the heat exchanger feed, thats just as easy but less parts, probably cheaper too just need some one to weld one join.
As i said there is more than one way to skin a cat.
Those coil wire things you speak of are not to handle more pressure, they are to ensure a nice bend when using tight radii with straight hoses.
In my 32 I ran my own completely new heater hoses using brass barbed fittings where I needed really tight bends and unicoils elsewhere (instead of using more barbed 90deg fittings and introducing more possibly failure points).
    • It might be worth having a good look at the chassis behind the bumper then; most people prefer the series 2 look so it might have been changed to cheaper parts as part of an earlier repair
    • The car itself a series 2. I was just curious about the headlights and just wanted to confirm that they were series 1. Good to know the rest of the front end is series 1. It’ll be easier for me to find parts on the aftermarket side of things lol
    • If you've wired up the coils & injectors properly, & have the neo CAS loom for the trigger, it should all work. The VCT works the same way so just different plugs between s1 & neo. Assuming DBW if no IAC. Don't bother with the stock boost solenoid with g4x.
    • THERE IS NO IAT SENSOR ON ANY SINGLE TURBO RB. And the one on an RB26 is not for "engine control" - it's really too big and too slow and is only used for over-temp alarming (as far as I can tell). Anyway, you don't have one. You want/need one for the Link, then you need to buy one, find a spot for it, and wire it in. You do know that the stock boost solenoid is not capable of "control", right? It is merely on or off, for the low boost (5 psi) and high boost (7psi), which the ECU enforces mostly based on gear. The stock solenoid is not for PWM control and is not plumbed up in a way to provide it. If you want to control boost properly, then you need a proper MAC valve. And yes, you can wire either of them direct to the ECU. Well, I assume you can - I don't know what the boost solenoid pins on the plug and play Link are capable of. They really should be as capable as any normal Link - but seeing as it is plg and play, it might be limited to stock functionality. Read the doco.   You really do just want to plug stuff together without understanding how it works, right? I can't help you there. I don't know the plug types or pinning on half the stuff you're asking about. If I had to do it I would sit down with the wiring diagrams, the car/looms and a multimeter and work out what is what.
    • Light should be a pressure switch, not a sensor.
