Hi Guys,
I've got an R31 series 2 Silhouette with Silvertop Rb20det.
Any idea how to wire up a HKS turbo timer? Anyone done this before..
The colours of the wires are Red, Green and Blue on one plug and two separate black and grey wires.
Any idea what these wires connect to?
Cheers
https://www.sau.com.au/forums/topic/38722-wiring-up-a-turbo-timer-please-help/
Im assuming you dont have instructions!!!!
You will have to post the model no so someone else who has the exact same model can scan it and send them too you, cause different wire colours mean nothing, on different brands and models... Also if you have one with no instructions i hope you bought it from a very reliable source??? Cause theift is a supply & demand industry...
or
sorry to be hard there dude I just hate theives anyway, I had one of these and returned it because the HKS ones dont like alarm systems that disable fuel pumps and so on... Mate if you have the reciept still return it for an APEXI pen type TT. Much more user friendlly and like alarms systems....
NOTE: You can make the HKS unit work with alarms, but its more wiring than im gonna even try to explain... (I used to be an auto-elec)
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
