So it appears that my 4th gear is on the way out - I believe it's out of sync. Just starting to crunch when going 5th to 4th and sometimes 3rd into 4th-under higher revvs normally.
Does anybody know someone/rebuild gearboxes and have an idea on prices etc or rexomendations on who is best to see?
Or alternatively am I better off sourcing another second second hand box?
I'm running r33 s1.5 box in my 34 so I'd like to keep the push type clutch as it's only 5000km since fitted.
Any advice appreciated. Thanks
dump the oil and put in Redline MTL or 80-90 wt oil,(NOT SHOCKPROOF!!!) that solves most cases without tearing the box apart. 4gear failure ??? normally its 2nd from ham fisted shifting
other synthetic oil wont do the same job to help the tranny .... believe me.
shockproof is too slippery for synchros to mesh properly dont use it on a 5 spd skyline
did you change the spigot bearing ???? if not that can cause the same problems when it goes
I will give an oil change as suggested and see what that does. Gearbox has only been in for 5000 km - came from a 33 I wrecked and I know the previous owner had no troubles.
I Didnt put the box in myself -Someone did it for me as I was to busy at the time- but from memory the spigot bearing was replaced- the oil in the box prior to instalation was very poor and dirty and I would think that the oil put in since then-5000km- really should be replaced anyway.
Thanks simon- if oil change does nothing I will pm you regarding contact :)
yeah if the oil doesnt solve it mate and the clutch is installed right ,
then a good box builder is rare find. MV automatics are well known for autoboxes ... but nfi who can do 5 spds worth a shite . it takes a lot of special tools to rebuild boxes in most cases
Redline has been the only oil that seems to fix up 5 spds with borderline issues, I've tried all of them over a lot of years . amsoil would be my next choice but its super hard to find and expensive as hell.
watch out too redline comes in US amounts quarts ,gallons not litres so get enough for your box. about 100 bucks or so is normal cost and lasts for a long long time. if It wasnt such a pain to catch and refill I would let you have mine to test it in your box before buying it. its only 6 months old , maybe 3k on it .... but being dumped in two weeks to fit a new NPC clutch/flywheel, nismo short shift and tranny seals and refilled with new MTL ??? bring a bucket to the shop ..lol
and simon ash is running my car up on the dyno and the nistune afterwards , should be interesting :thumbsup:
Thanks for the advice. I'm about to pick up a bottle from autobahn $114!!! Il drop it and replace and see what difference it makes and let you know. Hoping this solves it as I really wasn't budgeting for a rebuild or new box. Haha if I was in the city I'd swing by with a bucket cos it's always good being a tightarse :D.. lol..,but bein in the hills makes it probably a bit much work!
Clutch should be Installed right-it was done by a workshop-
Will let you know how I go shortly.
Redline doesnt recommend shockproof in the stock 5 spd Skyline boxes , it can cause problems with the brass synchros , "Redline Australia techs words when I called them for sponsorship/group buy discounts"
drag 5spd or ham fisted shifts it might protect the gears but not for street use
I run it in rear axle Nismo LSD , the temp is way lower and lockup is much much better, way better then the Nismo gear oil it had before, just odd when you have Blue smurfs blood in 140W that pours out of the bottle like coke not like the normal gear oil of old days.
if you want to see some interesting things, put normal engine oil in a cup and deep freeze it, synthetic in another , leave for a day , then try to pour it out, normal oil will be frozen nearly solid the synthetic will pour near normal. even 0W normal oil will freeze and need a spoon to get out,
(never use 0w in australia unless your running in the snow fields all the time)
Thanks for the advice Troy. Have changed it and it runs a hell of a lot smoother. Seems to of cleaned up the crunching with the small spin I took it on. If it does reoccur I will give you a pm Simon for contact details. Many thanks. Eli
No problems- will do. Took it for another long drive up the south eastern freeway this avo and it has been smooth and noticeably different in every gear. It was crunching more under higher revs previously so next time I'm out giving it a bit more il see how it goes but il be surprised if it does crunch at all. Thanks again.
your welcome, you will also notice the tranny temp is lower now , and power loss to the drivetrain is less = more power at the wheels , ever bit less friction helps
the same holds true for the engine oils etc. you can feel the difference instantly after changing to it . (it is the only oil certified for use on F18 engines that spin extremely fast. faster then a turbo )
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
