Classic Classifieds--------------------Classic Classifieds---------------------------Classic Classifieds--------------------
The powers that be are getting rid of all the For Sale subforums so our request had been denied.
This will have to do.
Some rules.
Only post the advertisement.
if the item is sold, quote the advertisement and post sold.
no chit chat in the thread, all enquiries are to be done via pm
there will be no bumping required, or tolerated, the thread will be stickied
The more info you put in the advertisement, the less questions you will have to answer via PM.(post a basic ad, expect heaps of questions)
If these rules cannot be adhered to, the thread will be deleted.
Happy selling!
  • Replies 113
For Sales:
1x reconditioned power steering box to suit R30 Skyline
Very good nic, only 3 years use. High Pressure line has been sold.
Located in Canberra. Can post (is quite weighty though)
Get rid of excess steering slop!
Pics, can be emailed. (Cant upload here at work)
Contact details:
email [email protected]
Price:
Best Offer. Funds to go to current HR30 restoration project (has 300,000km so is a bit tired!)
For Sale:
my L24 motor and 5sp gearbox.
motor is a reco from 1990. i swear for it's reliablilty. the thing never let me down in the 2.5 years that i daily drove it. would take it around australia without a sweat.
motor is stock and was treated like it should. the motor wasnt used for burnouts or anything stupid cause it's not a performance engine and was driven accordingly.
the motor is stock, complete, and running. will throw in coil and balast resistor and radiator as well.
5sp g/box is currently attached to the engine and would prefer to keep it that way. but will separate if i have to.
it has an Exeedy 'sports tuff' heavy duty single with only around 10,000ks on it so works perfect.
notable note: going from 3rd to 2nd makes a crunch when you put it in. never really bothered me though.
all other gears work perfect. no noises. never clutch dumped.
buying this stuff will be helping me finish mandie. which isnt far off!
throw me your offers people.
im in brisbane :-)
Wanted To Buy:
C210 Skyline
I am looking to start my next project so I am looking for a C210. I am looking for something to restore to original condition so I would rather something unmodified. I would like to start with a good solid base, so something with good interior and 'ok' overall condition to minimise the amount of parts I need to source. I am however realistic enough to know that these things are getting rare so I am willing to look into any options that are put out there.
Beggers can't be choosers so happy to look at auto or manual and/or Coupe or sedan.
I am in Adelaide but willing to travel for the right car.
Please contact me via PM.
Thanks
Edited by rick31
Hi,
I've got a nice set of good condition chrome/black window winders. (Bought for the R30 but they don't fit!). One is missing the circlip. $50 plus postage.
JH
john, they are C210 ones mate :-)
Yes they are, the post got moved from the "C210 Parts..." thread. They were removed from a wrecked C210 at Jolly's, Dandenong over a year ago (or was it two?).
JH
For Sales:
Contact details:
Price:
$50.00?
  • 3 weeks later...
Wanted To Buy:
C210 Skyline
Thanks
Found one! :cheers:
Time to put together a shopping list :)
Hi Guys WTB Bigger then stock Fuel Injectors for fj20det in a 1985 dr30Rs-x and a Aftermarket ECU Either Standalone Microtech with loom to suit fj20 as well or any other ecu configs you may have as a kit etc sr20 conversion kit, Thanks
EOI/FS:
MR30 L24E Intake manifold and all the crap it has on it - $10
HGC210 L20ET Intake Manifold and all the crap it has on it - $10
or I'm ditching them in 2 weeks.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
    • Well, it is an unusual noise. Use a 2 foot long bit of garden hose stuck in your ear as a stethoscope to pin it down to a definite location. We'll never work it out across the internet.
