ok so the event info is up so thought I would break this out:
http://www.skylinesaustralia.com/forums/topic/391124-saunsw-wakefield-track-day-new-pricing/page__gopid__6233486#entry6233486
and if looking for a double header:
Wakefield have the nissan sports car club there the following day:
http://www.wakefieldpark.com.au/event-details?event=288
and they seem to imply they are only $80 for the day:
http://www.nissansportscarclub.org/index.php?categoryid=35
I'm entering and think a few others will be coming along.
https://www.sau.com.au/forums/topic/387260-wakefield-park-24th-march/
Err... why cant you just have untimed passenger session after lunch?
Thats what most clubs do down here.
That way you get 3-4 sessions of timing :)
^^^^^^What he said^^^^^^^^.
Members poll > http://www.skylinesaustralia.com/forums/topic/354348-sau-track-day-timed-or-passengers/
We've spent a lot of time discussing and arriving at our club track day format. The majority of our track day attendees are still newer track goers and value taking instructors and mates for rides anytime. Also the additional cost of the timing just adds more cost to the day.
There are a few members that really want lap times and we suggest getting personal timing equipment. There are lots of affordable personal timing options now. I've been using a GPS logger for a year and was a great $175 spent! Does more than just timing laps too cause you can see your entry/exit speed and sector times. The club is still doing research on devices to pick up a few for those that really want a lap time.
So this really just comes down to a difference between the way VIC & NSW run track day events. We've spent a lot of time evaluating and discussing this in NSW and why we have chosen the "social fun day" atmosphere.
There is also the National event coming up for those that want to run Wakefield with Natsoft timing this year.
So come along and enjoy a great social track day.
Sorry, fire'y topic.
Quite a few of the track day vic guys have GPS timing now, including myself (racechrono + qstarz). It is just that natsoft is the benchmark.
I can see that it is more of a 'social fun day', which is great as passenger laps are great fun (Tampered Motorsport run passenger all day at Winton as well, though with timing).
Have you discussed with committee and/or AASA about running timing and passenger laps all day, with the timing published at the conclusion of the event only?
Either way I should be signing up for some Wakie action.
  • 1 month later...
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
