Car is much angrier with the fuel pump in. I wound in some more boost ...., wound in some more timing ... and took fuel OUT of the transition point as it was too rich, seems to hold 12.5 all the way through(might just be the cold air).
What do you think is going to happen when it is 28c outside and you've been idling at a red light for 2 minutes after giving it a flogging (massive heat soak) ? My guess is it is going to detonate.
Either set up a coolant temp/intake temp ignition trim fuel richen map, or retune it on a hot day if you want the motor to last.
  • 4 weeks later...
An update to this.
Fixed boost controller leak, now running 17psi and in 3rd and 4th I have that by 4k rpm, a few more revs needed in second (I have a plumb back bov though so once it's on it stays on well between changes - this is a track car).
Installed RX7 460cc injectors (These are from an 88-89 FC Non turbo and ease of fitmet depends on what seals were provided, but otherwise go straight in. Cheaper than GT-R units by a good margin and were cleaned and had new seals/pintles and are 20% larger than stockers instead of only 16% like the GT-R units. Guy on ebay seals them from the US.
Installed Z32 AFM.
Bought a remap from the UK (for GT-R injectors, Z32 and GT2560 on 17psi) as CA tuning is much bigger over there and prices are hell cheap. Found my ECU had already been socketed so chip swap was 2 second job. Slightly larger injectors also gives me more head room and results in a richer tune which I like. (Base timing adjustment required also - timing light used).
Wideband shows AFR's on full boost at WOT do not go above 12, coming onto boost it's in the low to mid 11s just at transition.
Car feels largely the same up to about 100km/h but pulls harder and for longer than it did from 100-160+ now, it's happy enough holding that boost til 7krpm too and I'm not game to rev a stocker any further and will likely only do that on hot laps.
At least now if I clutch kick it in second at 70-80km/h it'll spin and keep spinning.
Off to Winton on Monday to see if the lap time can be improved at all.
Should have clarified. Remap from a tuner for those mods. In the UK they do it need for speed style stage 1 = these mods, stage 2 = some other mods, stage 3 = the mods I have (with the exception of my slightly larger injectors). The UK has a much larger CA user base and as the CA ECU is so easy to socket and swap EPROMS in there are Remap chips available very cheaply everywhere.
You're right, I can get a Nistune for that money, which I simply can't justify on a hobby. Dr Drifts Remaps are $350 also.
This one, from a tuner who is tried and proven on a number of CA forums in the UK, was $35 delivered. If you're like me that'd make you very skeptical but after doing a few months of research into others who use them, speaking with the tuner himself, and getting plenty of referrals on CA forums SXOC and Driftworks are two notable examples, I was willing to take the risk. Backyard cheapo modding at its very best.
AFRs are good according to my wideband and the car drives very well on and off boost. I wouldn't call it doughy at all, not sure where you get the 10% richer figure from (The RX7 injectors are only 4-5% larger than the GT-R ones that the Remap is tuned for). Do you mean being in the 11s at the transition point? I fiddled with that a little in the SAFC (still wired in but values zero'd as it allows me to watch knock and monitor peak revs etc) and it made no bum dyno difference.
I agree with you completely that a full tune by a good tuner with a Nistune would be superior, but I'm willing to sacrifice 10kw and maybe some response for $600+ saving which would get me 3 more track days or another set of tyres.
Edited by ActionDan
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
