Hi guys,
Thought i'd ask people their opinion about my 98 model R34.
I sustained multiple hail damages to my car (all along the right side, the bonnet, hood and boot). Some are visible front on but many, are only seen side on and at an angle. (The black dots are placed near all the dent sites).
Now my excess is $1700, its with JustCar and I got a quote from a panel beater (Mill Park and South Morang Smash Repairs) for PDR for ~$4,000.
My question are, is that reasonable and will they be able to take out every single small dent so you will hardly see anything. Also what is my right (i.e. if I'm not happy with it can I get it redone or refuse to accept the car)?
Cheers!
Archie
https://www.sau.com.au/forums/topic/387285-hail-damage/
paint-less dent removal is normally pretty good. I've seen cars that were done from the big hailstorm in se melb a year ago, and they look brand new.
I'm not sure about your right to refuse the car however.
Just a tip, if you were not driving the car at the time, make sure JustCar is not adding in the age (driver) excess fee. as i had my old r34 written off from hail, and because i was not driving the excess was lower.
https://www.sau.com.au/forums/topic/387285-hail-damage/#findComment-6180510
We just got in around 4 - 5 cars with hail damage at work... Ranging from mild to pretty bad. We got a fella out today that does PDR to have a go at one that wasnt too bad with pretty mild dents and when he was done you couldnt even tell they where once there. But they do cost alot especially when removing hail damage.
Edited by Even_Flow
https://www.sau.com.au/forums/topic/387285-hail-damage/#findComment-6184020
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
