Tein Super Street suspension with Electronic Damping Force Controller (EDFC) as brought in by Fulcrum Suspensions.
Comes with everything shown in the first photo including original box, adjustment spanners, manuals, stickers (all new and unused) as well as the wiring harnesses etc.
Driven about 10,000km in my daily driver and then replaced when I wanted to start doing some really serious track work.
The Electronic Damping Force Controller allows you to dial in what damping force you want while actually driving, you can hear the little motors on top of each strut doing the adjustment in real time. Has memories for different settings so you can go from soft to hard with 1 of 3 memory settings. Alternatively dial in independently front and rear settings to get it setup just right for your car and driving conditions and then save as new memory etc.
All working well and as the photos show, in fantastic condition.
Not sure if they'll suit other models or cars, but taken off my R33 GTR.
Located in Adelaide, SA. Let me know if you need to know shipping estimates, etc.
Asking $2,000.
Let me know if you have any other questions.
Edited by cardre
For those looking at shipping costs, I've just measured and weighed the original box with everything in it:
27.2 kg
90 x 32 x 33 cm
Let me know if you'd like a quote and if you have a preference for a courier.
Thanks.
I've done a quote with e-go to ship to NSW and it was just over $30 to ship based on their website quoting service. Let me know your postcode if you'd like me to get a quote to ship using this or another courier.
  • 4 weeks later...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
