Hi all,
I desperately need some help.
I have a problem with my drivers seat, the seat is quite loose and I believe the seat rails have either broken away from the car or the seat itself.
I am trying to track down a solution to this problem . I have located a replacement drivers seat however the seat is a cloth sided one while mine is leather sided. Soo...
If this is my only option could I swap the rails over from the new seat to my old one?
If the first doesn't work are the coupe / sedan seats and rails interchangeable ?
Any advice would be appreciated.
BTW I have a V35 350GT8 sedan premium edition
And live in NSW just north of Sydney .
Thanks
https://www.sau.com.au/forums/topic/387294-need-advice-on-v35-drivers-seat/
^^ I had contemplated this however my mechanic is pretty sure from looking at it in the car it is a problem with the rails , however advised me to source a new seat or rails first because he feels if we take it out of the car we could well and truly stuff the rails and I will not have a car to drive then.
on my coupe the height adgustment rod snapped, i just got it welded. the seat comes out real easy, just 4 bolts, and a few clip plugs, you can get it out in 5 mins, take it out and have a look for a break.
This sounds like this may be the case as my seat rocks back and forth , all the electrics still work but whatever position you put the seat in it rocks
if your going to take the seat out make sure you disconnect the battery as i recall there being an issue with the airbag light coming on and staying on once the wires are unplugged.
should be some forum topics on G35 driver about it.
Check out this link of removing the front seats
http://g35nyc.com/forums/showthread.php?t=27865
Edited by mellowman
  • 10 years later...
I found this thread today while looking for solutions to my "electric seat switches on passenger side do not work anymore", and when I did a google search I found a video that was uploaded literally 10 minutes ago and it's exactly what you were looking for, just 10 years late, hope it helps!
    • What blows me away, is watching some of the US guys, like Tony Angelo at Stay Tuned. LS1, buys a set of heads for $1200, drops a mild cam in, pulls all the electrics, drops a basic inlet manifold with a carb, MSD thing for spark, and roll it out to make 550hp.
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
