The police have their "defect your car" thing happening at the reast area between Campbelltown and Picton Rd.
It's the full disaster with at least 3 cop cars patrolling, van/bus setup at the rest area, witches hats, defectomatics etc etc.
They are basically pulling over anything with shiny wheels and giving them the full fine tooth comb treatment.
Get off at Campbelltown and either go via Appin/Wilton, or Narellan Rd, Camden Bypass/Picton.
Get back on at Picton Rd.
https://www.sau.com.au/forums/topic/387378-warning-sydney-summernats-goers/
Ok, so I know all cars should be lawful and engineered and all, but seriously, why target people that are heading to an event that is trying to take stupid driving off the street?
It's defect stations like this that I think would deter people from going.
I'm not going, but still appreciate the heads up for others that are.
why wouldn't they set up a defect station? they will get heaps of cars with illegal mods, plus a heap with bald tyres, etc. it's like setting up a RBT down the road from a beer tasting festival. makes more sense than doing it down the road from a primary school in the middle of the day in the holidays.....
This.
Also, I won't be going either, but thank you for the heads up.
I didn't know a beer tasting festival is a driving event. I generally agree with your point, i just think that that's a bad analogy
i wasn't saying that a beer tasting festival was a driving event. more just stating that there is a higher chance of someone drink driving there than normal times, in the same way that they have more chance of finding cars with illegal mods/defects at something like winternats. i'm also sure that they will get plenty of cars with near bald tyres, which i think we can all agree is a genuine safety issue as it drastically reduces grip in the wet.
They don't have to defect cars with illegal mods or for being unroadworthy. Even a bone stock car "can" be defected for suspicion of modifications.
If you go out doing 200km/h on a back road at 3am and don't get caught, then go to summernats, get defected on the way there, EPA'd in the mail, what are you going to do from then on? These events need to be encouraged and supported by police, defecting someone for an empty washer bottle on a sunny day is not support....
yeah but you also get plenty of muppets that go to these events, never participate, but then proceed to bomb up skids as they leave the car park. i've seen this happen plenty of times at all types of events from test and tunes to skidpan days to top level motorsport events. so you can't really blame the cops for targetting an obvious location.
Not at all.
But why not stop people doing this purely by bulk presence, as in zero tolerance out of the event? Instead of setting up a defect central zone BEFORE they get there?
Doing skids leaving the gate etc. is plain stupid and obviously bad for it's image, so that sort of thing SHOULD be targeted, not the ones behaving themselves driving sensibly to somewhere safe to let loose.....
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
