Hey guys I have a set of xxr 521.
They are brand new, 2 are in boxes still sealed an the the other two I just got fitted with brand new 235/40 yesterday!
They are dark grey all around
18x10+25 for all 4
Price 1200$.
Only reason for sale is that I saw some blitz 03 for sale at the shop when I was getting tyres fitted and now I think I want them lol
Pics can be text
0423455146
Located Melbourne south east bayside
https://www.sau.com.au/forums/topic/387450-bbs-lm-copys-18x1025/
I think you have to run a 5mm slip on to clear 4 pots. I run 25 mm spacers on my current wheels and haven't actually taken spacers off to test fit as you need someone holding foot brake to take spacer of the front.
ahh cheers for that..
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
