R33 Series 2 4 Door Parts
Hey guys
Have a crashed r33 4 door series 2 that im wrecking.
Still have the engine, which has done 115,000 kms, was running with auto gearbox $1000
600x300x75 FMIC with piping to suit R33. $350
Electronic Boost Controller, Greddy, all parts to hook it up $250
Still have most of the interior pieces which are in immaculate condition
Many other little bits and pieces left.
Car will be taken to the scrap yard within the next month, so dont hesitate to make offers on any parts
 Share
    • I'd try the Jaycar one first. Don't even bother with replacing the passthroughs, as they will still work provided the melting is only minor and they still seal and insulate. You can always go back and replace those later. After you've put the new crimps on, you just have to make the pump work for a bit, then go back there and laser gun the terminals (or touch if you're brave enough) to see if they are sufficiently cool to relieve your concern. You might want to gather a data point with the old setup first, to see how hot they get now.
    • This might be another option too if the surgery allows for a straight lug to be used. Jaycar rates them at 30 amps -  https://www.jaycar.com.au/6mm-non-insulated-eye-terminal-4mm2-pack-of-8/p/PT4932
    • @GTSBoy Makes sense.  I'm guessing we'd have to use a cable lug, its tricky finding lugs suited for wire smaller then 0 gauge, but this looks like it might work? https://au.element14.com/panduit/lca10-10f-l/terminal-compression-lug-10-10awg/dp/2944903?CMP=KNC-GAU-GEN-SHOPPING-PLA-PMAX&mckv=_dc|pcrid||pkw||pmt||slid||product|2944903|pgrid||ptaid||&gad_source=1&gclid=CjwKCAjw4ri0BhAvEiwA8oo6F3hR5QEQH43vntEUad27nYgwWzBmgdiYNqiQLBMe3C9pkkncxgv3oRoCciEQAvD_BwE Just need to do some surgery on the bottom of the bulkhead as even fitting the tiny ring connectors space is tight.  But now that I'm in this situation, do I buy another stock bulkhead and give the bigger lugs a go or do I just drop $1000 on a frenchy setup? Hmmm.
    • Yeah, see, I think I've worked out what is happening here. You (and other people) buy these massive "40 amp rated" pass throughs, and use fat wires, then make the connection between them using a ring crimp that has a much smaller cross section in that piece in the neck between the crimp and the ring terminal than any other part of the system. And it gets hot there. And because it is very well connected to the passthrough....that gets hot too. We probably need to be using more chunky wire terminations.
    • Disconnecting a coilpack/injector isn't 100% on identifying anything other than the suspect cylinder.   If doing it you note one in particular makes no difference at all, you've got a total miss on that cylinder, it could still be for numerous reasons. If you do it, and one cylinder affects the idle less than all the others, now you t least have a suspect cylinder. I'd be doing a compression check on all cylinders first up. If they're out of spec, do a leak down on it too.   Secondly, grab a video of this idle and stick it up here.
