  • Replies 60
Posted Images
Compare the decel fuel cut set points in your tune against the ones in the standard tune. If it has been fiddled with by the tuner, it might have been fiddled with poorly, or to cover some other problem that has since been fixed or otherwise changed. But my recommendation to you is to stop stuffing around asking questions like this on a forum and take the bloody thing to a decent mechanic/tuner who can test it out with some diagnostic gear attached and see what is actually happening. Instead of keeping going like this day after day you could have it fixed in an hour or less.
GTSBoy you could be validating a good suggestion about the decel cut points, maybe thats the problem, but why now all of a sudden after fitting my dump and O2 sensor?
As for taking it to a decent mech/ tuner, it would be at Unigroup already... If i had my licence, or a fultime driver....
I'd say it's just as likely to be coincidental as being caused by anything you did. But a decent dump will affect the overall breathing of the engine and so might have tipped your engine over the edge of some failure that was waiting to happen.
Anyway, I agree with Hanaldo. Put it on a truck and get it fixed, or put it up on blocks and don't fix it until you get your license back.
Lol at putting it up on blocks, but putting it on a truck and off to tuners is simply not smart financial sense as i dont need the car fixed asap, being suspended makes me all the more determined to bite tooth and nail, hunt for solutions and keep my car 'perfectly prepared' and waiting for me when i get it back. Not only does it keep me bUsy with an interesting hobby of tinkering with cars, but its taught me a huge amount of stuff and made me more n more confident at fixing little bits n pieces along the way while also keeping dosh in my pocket than into someonelse's, theres every bit of chance to get ripped off anywhere in this industry, such as Hanaldo's $300 intake...or was it more? Wink;
There seem to be a lot of members of sau with autos and mostly atmo aftermarket bovs who seem to encounter this exact problem of stalling upon rapid release of the throttle. Example stopping at lights or slowing down after WOT. Mine is a manual with stock plumb back bov, so tryin to figure out if thats the cause.
i have had problems with staling at lights and feels like loss of power and when driveing on freeway bit of a jerk like car went off and on, changed my coils improved it allot but still had bit of a jerk, at the end it was the fuel filter that was blocked to the shit house that literlly made my car stop completely and jerk while driving on freeway, this is on my 33. on my 32 i had problem staling at lights also and ended up being breather hose on my fuel tank every time i turn corner or some thing air went in system and shut off my car so replace that got power back and no more stalling, so with your problem could be a fuel issue and ignition. maybe fuel pump on way out or fuel filter blocked with gunk, i suggest changing fuel filter first because it really cheap and easy and get fuel pump tested, maybe pump not pumping enough fuel or just not working properly, hope this help and is the issue, and check and tighten all the clamps maybe a leak some where but doesnt sound like that to me. good luck i check in.
Ha, that's cute man. Carry on then, you've clearly got it sorted.
well there is nothin wrong with trying to fix it your self and save some dosh for other mods, thats why we got this forum to help people who like fix and doing there own cars and also vise verser. Not every one got allot of money,
He doesn't have a license. If he did I would be encouraging him. But imagine if you got cleaned up by a dude with no license messing around with his car.
fair enough he shouldnt be driving the car at all agree with you there , he should get one that has licience to test it to see if problem does not exists and he can continue fixing it,
and you should not be driving it with out a licence or else no one would be helping you out, get your dad to see if problem gone or a friend with a licence to drive it.
Definitely should not be driving it, but did a couple of 5 minute runs, otherwise I get my friend to take it out when he is available.. Thanks for the suggestions on what could be potentially wrong with the car.
i notive you have a T boost controll, i herd that they meant to stuff up and spike boost up and down and stuff up completely i suggest getting a electronic boost controller can get one cheap of justjap.com search them up on google or visit there forum threads here.
sorry for double post dunno what happen :S
Edited by BRUNSKIGTST
Thanks, my boost holds nicely though - goes to 10-12psi very quickly and stays there, only drops to 10 from 12psi. Not unstable at all.. It is a funny issue, this engine shutting off - I have ruled the O2 sensor out because it does it even with it unplugged, battery is definitely ruled out, fuel filter wouldn't be more than 10000kms old, more like 5000km, but will change that I think.
I am thinking its either the deceleration cut-out points in the tune or the stock bov leaking? A lot of people have this problem in all sorts of cars - and the culprit seems to be these things or the O2 sensor or even the IACV and TPS
It could be the bov causing a lot of reverberation? But I'm guessing it's the stock intake pipe, and it's a recently occurring issue, so I doubt it's that. I wouldn't expect it to have much to do with the bov.
My money is still on the O2 sensor. Disconnecting it does not necessarily mean it CAN'T be the O2 sensor, because the ECU is still expecting it's feedback. You would have to edit the tune to set the O2 feedback temp very high to effectively rule it out. But then again, I would expect it to be causing more issues at idle/cruise if there was a problem with it, not only at decel. Are there any other issues, apart from the cutting out at high rpm? Does it idle nicely, cruise nicely, etc?
This is why I suggest you take it to a tuner. You might be getting a DTC which could be checked through consult. So if you insist on doing it yourself, at least get a consult cable and download ECUtalk or a similar program and check your codes, you might save a lot of time.
*EDIT* Just read your O2 sensor is not done up tightly. Speaking from experience, you need to do that up tightly to get it to seal properly. I cross threaded my stock O2 by putting it in when the exhaust was hot, and ended up with a big exhaust leak. I suggest you fix things like that before continuing to diagnose, it's such an easy fix and might be the issue all together.
Edited by Hanaldo
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
