It could be the bov causing a lot of reverberation? But I'm guessing it's the stock intake pipe, and it's a recently occurring issue, so I doubt it's that. I wouldn't expect it to have much to do with the bov.
My money is still on the O2 sensor. Disconnecting it does not necessarily mean it CAN'T be the O2 sensor, because the ECU is still expecting it's feedback. You would have to edit the tune to set the O2 feedback temp very high to effectively rule it out. But then again, I would expect it to be causing more issues at idle/cruise if there was a problem with it, not only at decel. Are there any other issues, apart from the cutting out at high rpm? Does it idle nicely, cruise nicely, etc?
This is why I suggest you take it to a tuner. You might be getting a DTC which could be checked through consult. So if you insist on doing it yourself, at least get a consult cable and download ECUtalk or a similar program and check your codes, you might save a lot of time.
*EDIT* Just read your O2 sensor is not done up tightly. Speaking from experience, you need to do that up tightly to get it to seal properly. I cross threaded my stock O2 by putting it in when the exhaust was hot, and ended up with a big exhaust leak. I suggest you fix things like that before continuing to diagnose, it's such an easy fix and might be the issue all together.
Ok, I'm hoping against hope its the bloody O2 sensor. There's no other problems whatsoever, but as mentioned earlier, when my friend took it for a run (O2 sensor connected), it felt noticeably sluggish and missing a fair chunk of power and torque, boost was ok normal, revving to 7000rpms was normal and clean, but there wasn't much shove/kick and it was slow to come too, had to hold pedal to floor to get the same amount of kick that normally comes at 3500-4000rpm. It was a HOT day, engine bay temps were hot as. Then yesterday I disconnected the O2 sensor (AND TIGHTENED IT WELL) and it felt powerful and snappy like before, no dramas. Boosting, revving, engine sound and drivabilty has always been smooth and clean. Maybe the ecu didnt pick up the O2 sensor then (when it was sluggish).
Now the only remaining problem is the engine shutting down on quick throttle release, whether after WOT or coming to a stop at lights or pulling into drive...pinch.gif
Might need to get a little laptop, ecutalk and a Nissan consult cable (cable off ebay good??) This is what I found: http://www.ebay.com/itm/Nissan-Consult-Diagnostic-Scanner-Cable-14-pin-Reader-NSN-OBD-Fast-USA-Ship-/260924083182?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ANissan&vxp=mtr&hash=item3cc0498bee
Or wait to get licence back and off to Yavuz..
Edited by rondofj
  • Replies 60
Posted Images
Hanaldo, O2 sensor is already tight now, before I went for a drive yesterday..:thumbsup: Power is back..but that was just one test so... BTW what is DTC, I only know TDC - top dead centre (timing).. The loss of power earlier COULD have been from the O2 sensor being only hand-tight then..:teehee:
Edited by rondofj
I'd still be thinking boost leak, I had this issue with an auto as you said. Turned out it was a combination of a dieing AFM having a dry solder joint and a slight boost leak on the added t for a boost gauge.
Still running the stock rubber inlet pipe, the one from the AFM to the turbo? If you are, have you looked into the fact that it may be sucking closed under full throttle? Big restriction there that will cause poor performance.
It is getting hotter and engine bay temps would be getting hotter making the rubber softer. It is a common issue, search for "$5 intake mod" and you should find a whole DIY thread about fixing it.
When engine shuts down, three lights come on in dash- battery light, engine light and teapot light (oil press?)
Well, when the engine shuts down, the key is still in the "run" position, and the lights are saying "no charge", "no oil pressure" and "no engine(?)". If you notice, these three are on before you ever start the engine (just before you switch to "start").
You've got a tuneable ECU - add some fuel and timing to the rpm bands just below the idle band, see if that helps with the stalling.
Turn your idle screw up higher Ron, u cleaned the aac it may need resetting. Wind it out a full turn and get ur mate to see if its fixed. Please stop posting if u drive it urself. Just say "ur mate was driving". We are not the only ones that read these forums ;)
Hehe good idea Jez. I am very grateful to u guys, ya all rock bigtime :).. To Qwk32, I am yet to make a proper steel intake, when Jez tuned my car we made absolutely sure the intake wasnt sucking shut, and it didnt let us down thankfully. Same mods n boost then except the dump.
As for adding fuel n timing to the idle points, I dont have the Nistune licence, laptop and cable to do so yet, but hopefully soon. I trust Jez had got this right when he tuned so it could have gone off whack with the new O2 sensor. What say DVS?
I will definitely turn that idle screw to fully 'open' counterclockwise, correct?? Then get my mate to go for another run. To me it seems more n more a lack of air/ vacuum issue, the way it happens, like sucking all the air out from the intake on quick throttle release..
Cat's good of course - a 100 cell metal item, and ecu's been reset - today after work I will turn that idle screw open because I know I closed it too far to shut up the idle when I cleaned it.. This WILL solve my problem.. Well I think so..:worship:
ps: i love your ghetto exhaust holder with 2 hose clamps LOL
hahahaha I have no choice mate, I cannot drive to the exhaust shop...Was gona get some metal ties for the time being..
I will do the idle screw thing first tonite and let you know. What does the low boost do? Prevent less boost leak / air getting sucked from a suspected leak? I'm scared to play with the manual boost control as when I wind it back up, I do not want to overboost past 12psi..
Car fixed guys, i mean like completely, just fixed it now..no more engine shutting off, wheelspin in first n second easy as pie and a good solid shove in nuts when i want...
So what was the problem you ask. Such the simplest of all things fellas...eeeehh ..grins bigtime like a cheeky mofo...shut the fk up and tell... Eeeeh will wait for a few guesses, ... Then the story comes, hope to help others with same problem
Ok before i go to bed... It was one of those straw vacuum hoses onto intake manifold from near the brake servo area, broke free from a crack when i cleaned the aac valve, only just saw that it was hanging down when i went to loosen the idle screw.. Of all the little things causing such pain..
what a pain lol, i know how you feel, today i hit a pothole hard but not hard to buckle the wheel and car starting to go all funny like want to shut off and stuff so im geussing some thing went lose lol tmz im go over engine bay and tighten everything i see and see if things are connected lol,
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
