As far as I know, its a fact that BP Ultimate (who use the best Western Shelf Crude Oil) refine their fuel to 98 octane, where optimax is like putting a bottle of octane booster in your tank.
I have it on good authority.
I don't use the crap.
BASS OUT
So Bass, what do you get when you buy Ultimate in Sydney, where there is no BP refinery? What about Melbourne, where there is also no BP refinery? Ask your "good authority" where Western Shelf Crude is actually refined?
  • Replies 82
Shell doesnt even sell Optimax in perth as a 98 octane fuel, We only get Ultimate and Vortex (which For our engines doesnt have high enough ron).
I would guess that is because it isn't worthwhile for Shell to ship Optimax accross the desert. They would have to charge more than BP, with their local refinery.
bs my car runs quite happily on Vortex and notice barely any difference between it and the 98RON stuff. Maybe if I was taking it on the track or drag strip, but for the road its fine.
I run Optimax without problem.
TonyGTst has told me he's had no issue with using Vortex.
I have a fuel card for my job "free fuel, go me!!!" and the only premium I can buy is Vortex. I didn't have any problems with running it. Maybe people with more delicately tunned cars would notice a difference cause mine was pretty stock. I tried Optimax once and would never do it again. :)
I went through a complete fuel test using BP98, Vortex, Opimax, Mobil synergy98 in one day while trying to keep constant temps.
knock levels were as follows Higher being worse and 75+ being an audible ping.
BP98 :27
Mobil synergy :37
Optimax :69
Vortex :80
BP98 +30% toluene :30 (plus 7 degrees advance) =)
Tests were done in SA. I have run both BP98 and Optimax in Sydney and found BP98 to be better, however as Sydneykid and others have stated the shell refinery uses old technology and batches differ. I would never use any other fuel in SA accept BP98 as I always got exactely the same knock level. Here in Sydney my levels are always different...again backing the fact BP uses optimax. I have given up and now have a cheap supplier for toluene. I am yet to find a fuel here I can tune to and trust.
Damn. Good thing I don't put Vortex in a Skyline anymore. What’s the deal with Av-Gas. I have absolutely no idea what would happen if you put it in a car. Does anyone know??
AvGas has lots of lead in it, so filling up the cat and coating the lambda sensor.
I used Wynns pro strengh for ages until my plugs were coated to the max with brown red sot. Have heard reports that they clog injectors..... Have used Nulon as of late and the plugs seem to be cleaner. Nothing close to toluene tho. I have been using tolunene at the same cost for a bottle of booster for a while now. (Hint: It's used in printers and costs a fraction of the price $2.20 at litre) =) nice
Now that is interesting. I also noticed when I changed my plugs they had the brown red soot on them It must have been from the Wynns as you said cause I tried it for a while and didn't really notice any difference.
By the way what colour is Toluene? Blue Cyan or Magenta? Hehehe. :)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
