pfft. f**k gettin scared away from all the fun times associated with car shows/scene.
also when do we find out if weve been accepted?
  • Replies 85
That's excessively paranoid.
I'm happy to display my car in public. I don't paint my address on the windshield, I don't tell people what type of alarm it has, I don't tell them how often I drive it, where I drive it, nor where I park it.
Then when I'm done not telling people what I do with my car, I get it home, park it in a lock up garage, arm the alarm, and sleep peacefully knowing that should the worst come to pass, Adelaide is a small place, and it's fully insured... Just in case.
None of my Skylines ever got broken into nor even close and every one I've had has been regularly entered into show and shines and driven on a near daily basis.
for peace of mind i swap my plates to another set of plates i have here, and put a little bit of tape over the vin number etc. and ive never had any theft related issues
haha yeah a bit paraniod. i used to be in a couple clubs that would regularly have parts stolen from the display cars, even while we were standing there guarding them... small car sunday, autosalon, here and interstate....
Edited by Deep Dish V35
I have had my cars in about 200 shows around the country and have never lost a thing off them , i must be very unlucky !
Unofficial cruise from my place at 7am :) if you don't know where I live, don't ask, just be somewhere along North East Road just after 7am and listen for the rumble...
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
