High Five! All Japan Day Returns To Adelaide 26 February
Iron Chef
 Share
  • Replies 85
I've just moved over from WA and living in Glenelg, loving the fact that there is a car show nearly every weekend! Had a ute muster, Mini club, now All Japan and then Austin Healys in a couple of weeks, very cool.
I should have got on to the forums and entered! Saw a black, manual Stagea pretty much exactly like mine in every way haha.
Another great year. Great to meet some new members. The highlight was seeing the cops go after the Ferrari. Did anyone hear if they caught him? And having a drink at the watermark. Where all the SAU shirts were. Also cant wait to see Dave's photos.
Apparently he got away and then drove back down the same road later..
Great day and some very nice cars! Can't wait to get my coupe out maybe next year though.
Had a great day despite not being able to get my car there. putting my wheels on dions car was a tedious exercise that resulted in many lols.
cheers to all the sau buys that came and sank some bulmers at the watermark cheers.gif
Just to clarify, yes they got him.
He was dropping a mate to the airport, so he was told to come back and collect his fine or his car would be impounded, which is why he obviously came back (this is the black 458 Italia - the red one with the Iron Chef sticker that parked on the reserve had nothing to do with it). See, they don't only pick on imports! ;)
Seriously we smashed it out of the park today. So many awesome cars, and I'm still amazed at the number of spectators, we surely had over 1000 people drop by. Everyone was well behaved (with a couple of small exceptions) and Neil and the guys at SAPOL did a great job of chatting to owners and settling down the pelicans driving past.
Dave took a dozen photos and then gave up for the day.
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
