Police will only contact you if they find it, sorry to say but they won't do sh*t you have to take it on yourself and do as much as you can get eyes out and stuff, this is what I've done man and it's gettin me closer, also helps to know ppl on both sides of the law ;)
  • Replies 136
Posted Images
Over hear we have a service called "Where's my ride". It cost $200 or $250 a year.
I log into my account on the net and it pin points the exact location it is now and history of where it has been. Tracked by 7-9 Satelites.
Whilst it's mooving it reports every 60 seconds or less and even provides the speed and direction of the vehicle.
I'll be subscribing again in Feb when it comes up.
I'm lucky enough to have comprehensive, 3 point and clublock.
But this "where's my ride" is the most valuable to me. If I only had $250 to spend then this would be it.
That is a stupid f**king idea. So once they realise they don't have the right car they slap a defect on it.
hey if my car was stolen I'd want police doing this.. If the cars detectable they will get defected regardless, I got pulled over just yesterday and cops didn't even think to check for a defect, and I have no back seat in the car. You must meet some really f**k witted cops that are just out for defects, i only ever meet decent ones when im pulled over in the Skyline, and my cars got defectable problems all through it.
THE CAR HAS BEEN FOUND!!!!!!!!!!!!!!!!!!
Cops just called and told us that the car has been found in Pt Adelaide. It was used to rob the Belair hotel. Getting processed, but apparently theres a fair bit of console damage and concrete blocks on the backseat.
Good to hear it has been found but not good to hear what has happened to it. Hopefully insurance comp isn't nasty to you mate
Car was apparently last seen on king William rd before tye on the runt 1am on Australia day, had mud or dirt spray from all 4 wheels on the doors and rear panels, please if anyone see's this call the cops straight away or follow it and then call the cops. They have obviously changed the plates so I don't know how the cops will find out that it's stolen :/
That could had been me... I was in that exact spot at that exact time and my car was filthy...
I also got pulled over and questioned Sunday morning by the cops thinking it was your car as I drive a white 32 GTR.
You should really post some pictures up if you want people to spot it for you. Pictures tell a thousand words! If I happen to spot a white 32 GTR with some kind of wheels that look like SSR's, I'd probably think to myself "nice car... could be that one posted as stolen... probably not...", and I'd keep walking.
Another very similar situation to yours last year with an R31 that got pinched. Few pics were posted up, and people knew exactly what to look for. I even spotted it myself. And it was eventually recovered!
Were you wearing a hat? And do you have a goatie? My mate said that's all he saw just figured it was mine, just hoping..
Yeah I'll have to get some pics up tonIght, always on my phone so it's a bit hard just really hope it turns up really soon :/
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
