yeah i kinda cant be bothered gapping plugs anymore
i was told to get heat range 7s
and the problem is bursons no longer have BCPR on there system any more which makes me think theres a different part number for them now i think i can use bkr7e from memory which come pregapped
the only difference between the BK and BCP plugs is the length of the plug from the gasket to the top of the plug (where the coil plugs onto). the BK's are about 2.5mm shorter, could be enough to make a bad connection to the coil?
whether it has a v-groove or not is in the S part of the part number, BCPR6ES is a standard tip, BCPR6E is a v-groove tip.
i just picked up a set of BCPR7ES last week at supercheap, so you can still get them.
Edited by QWK32
ok cool as i might give that a shot
do u know who sells them pregapped to .8 i can get .9 from bursons but im thinking i might goto supercheap and get a gapping tool from them to kinda looks like a 20 cent coin if u know what i mean
im thinking about getting bcpr7es as i have a 25 with nstune ecu cooler exhaust 555cc injectors and 13-14psi for a month or 2 untill i sell my brand new gt3582 so i can get a gt3076 and put that on
get the plug p/n AGSP22YE09 from ford. genuine plug made by denso. my tuner insisted i use them as they are the best they've used and are platinum i think? and only 15 bucks each
Interesting you say this, i noticed when changing the spark plugs in mrs ba xr6 turbo, it had ngk plugs im pretty sure same part number as rb25det plugs... i decided to get some geniune ford plugs, they were marked denso and only cost me $60 for the set... i was thinking of replacing my r34 with the same plugs from ford anyone else can confirm this will be suitable?
Edited by rgr34
  • 5 years later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
