Rb25Det Spark Plugs
jet2nv
 Share
use bcpr6e they are gapped at .8 and have a better heat range you may struggle to get bcpr6e but you can get the bcpr6e-11 and regap to .8 plenty of this info in general maintenance
yeah i kinda cant be bothered gapping plugs anymore
i was told to get heat range 7s
and the problem is bursons no longer have BCPR on there system any more which makes me think theres a different part number for them now i think i can use bkr7e from memory which come pregapped
get the plug p/n AGSP22YE09 from ford. genuine plug made by denso. my tuner insisted i use them as they are the best they've used and are platinum i think? and only 15 bucks each
the only difference between the BK and BCP plugs is the length of the plug from the gasket to the top of the plug (where the coil plugs onto). the BK's are about 2.5mm shorter, could be enough to make a bad connection to the coil?
whether it has a v-groove or not is in the S part of the part number, BCPR6ES is a standard tip, BCPR6E is a v-groove tip.
i just picked up a set of BCPR7ES last week at supercheap, so you can still get them.
Edited by QWK32
i work at autobarn... they still make them
Yep, I go to Autobarn Bayswater, they have BCPR7ES, I wanted to try BCPR7E (the v groove) and those have to be ordered...
ok cool as i might give that a shot
do u know who sells them pregapped to .8 i can get .9 from bursons but im thinking i might goto supercheap and get a gapping tool from them to kinda looks like a 20 cent coin if u know what i mean
im thinking about getting bcpr7es as i have a 25 with nstune ecu cooler exhaust 555cc injectors and 13-14psi for a month or 2 untill i sell my brand new gt3582 so i can get a gt3076 and put that on
Interesting you say this, i noticed when changing the spark plugs in mrs ba xr6 turbo, it had ngk plugs im pretty sure same part number as rb25det plugs... i decided to get some geniune ford plugs, they were marked denso and only cost me $60 for the set... i was thinking of replacing my r34 with the same plugs from ford anyone else can confirm this will be suitable?
Edited by rgr34
  • 5 years later...
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
