yeah i kinda cant be bothered gapping plugs anymore
i was told to get heat range 7s
and the problem is bursons no longer have BCPR on there system any more which makes me think theres a different part number for them now i think i can use bkr7e from memory which come pregapped
the only difference between the BK and BCP plugs is the length of the plug from the gasket to the top of the plug (where the coil plugs onto). the BK's are about 2.5mm shorter, could be enough to make a bad connection to the coil?
whether it has a v-groove or not is in the S part of the part number, BCPR6ES is a standard tip, BCPR6E is a v-groove tip.
i just picked up a set of BCPR7ES last week at supercheap, so you can still get them.
Edited by QWK32
ok cool as i might give that a shot
do u know who sells them pregapped to .8 i can get .9 from bursons but im thinking i might goto supercheap and get a gapping tool from them to kinda looks like a 20 cent coin if u know what i mean
im thinking about getting bcpr7es as i have a 25 with nstune ecu cooler exhaust 555cc injectors and 13-14psi for a month or 2 untill i sell my brand new gt3582 so i can get a gt3076 and put that on
get the plug p/n AGSP22YE09 from ford. genuine plug made by denso. my tuner insisted i use them as they are the best they've used and are platinum i think? and only 15 bucks each
Interesting you say this, i noticed when changing the spark plugs in mrs ba xr6 turbo, it had ngk plugs im pretty sure same part number as rb25det plugs... i decided to get some geniune ford plugs, they were marked denso and only cost me $60 for the set... i was thinking of replacing my r34 with the same plugs from ford anyone else can confirm this will be suitable?
Edited by rgr34
  • 5 years later...
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
