Hi everyone.
Up for sale is my Stagea Autech version 260RS
I have not owned this car long but have put a fair bit of money into it and it is in awesome condition. Reason for selling is that my work car is coming to the end of its rego and life and the stagea is not the sort of car i want to be driving to work and leaving outdoors for 12.5 hours and i have found a new hobby of camping so looking to buy a turbo diesel 4x4 and not have to be paying 2 rego's and insurances. The stagea is lucky to get drivin once every 2 weeks so has only travelled less than 200km since ive owned it.
This car is truelly in great conditions... details are as follows:
2000 model
RB26dett (compression test recently done and came back very healthy. will post a pic of the results)
pearl white duco
interior is in excellent condition
factory bbs rims in near perfect conditions with pretty much brand new tyres (new tyres were fitted at dealership)
Adjustable coil over suspension (apparently cusco)
Aluminium radiator
All the usual power options which work fine
66613km (64150 when purchased)
I bought the car stock standard from a dealership in Sydney which still has warrenty till 18/09/2013 and have since made the following mild modifications:
Nismo gt le mans group A turbos (rated at 640hp)
Denso 700cc injectors
JJR adjustable cam gears
Walbro in tank fuel pump
Genuine Greddy clear cam gear cover
Xforce split dump pipes
JJR 2.5 - 3" front pipe
Catco highflow cat
custom mandrel bent cat back piping with resonator into 3" highflow oval muffler with twin tips (to still look factory)
Nismo air flow meters
Greddy profec B spec 2 boost controller (low - 10 p.s.i high - 18 p.s.i)
Apexi power fc tuned by blacktrack performance
Car is trully in excellent conditon inside and out which a couple of guys on the forum may be able to vouch for and gives you the luxury of having plenty of room and the RB26dett too so not your average family wagon.
Asking $24000 ono but not desperate to sell as it is a very clean car
Contact me on 0422642319 for more questions
will post pics from phone asap
Edited by livewire
Thanks for the compliment mate. It really is in awesome condition. It seems Gtr wagons are not the flavour of the month though lol. Good car with good mods for the price
No worries mate, it seems in excellent condition, and is excellent price.
In my opinion, GTR wagons would be every flavour of every month, such a sleeper thumbsup.gif.
    • Wish I had this advice when I did my pump. It went in and out 3 or 4 times, and on the last time it snapped.
    • Tried them, they leaked. I also foolishly bought some random rubber ones that leaked too.  Genuine and not looked back.    As always though sample size of one, and I could have made a mistake installing them.
    • Technically still manual process to set it first time though
    • Shit job but not hard. I'd use a piece of wood to knock the plastic lid open to avoid damaging it, use a vacuum to clean up the fuel sender lid also so crap doesn't fall in. I'd probably do pump and filter at the same time since you're already in there, I reused my OEM sock after a quick clean since the one provided wasn't long enough. Could also hardwire your pump if you feel inclined.
    • Supercheap auto sell this: https://www.supercheapauto.com.au/p/pat-plusquip-fuel-tank-lock-ring-tool---universal-kit/SPO3564082.html I own this and if you HAVE PATIENCE you can remove it without snapping lines and generally being incredibly angry, then said at doing this job. Sadly I've removed the pump about 75,000 times over the years. I don't know if you're a large lad or a smaller lad but my advice to you as someone who is 185cm is if you are my height or smaller, is to sit in the boot and take your time. Yes you can put the seal on. The seal goes over the white thing/lid (you will see how it 'slots' in) then the whole assembly presses into the tank. then you screw the lock ring on. I spent so much time doing things the wrong way by trying to mount the seal into the tank first, then putting the white fuel hat on in the space provided. Put it together first then it'll all go in. But seriously be careful about removing the hoses AND where the removal tool is moving relative to the plastic pipes coming out of the lid when you've removed it. IT IS BRITTLE So brittle in fact I have two spare lids, and would recommend buying a spare and having it handy before attempting to do this. May as well throw https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD in the tank as well, as this uses all stock plugs and such. You may need to/strongly recommend you re-use your OEM fuel sock or use the one supplied with a length of hose so it sits at the stock height.
