'88 Toyota Camry!
G'day guys,
Throwing an add up of my toyota camry, had it for 5 years and it's never let me down.
Kms: 116,400
Int. and ext. Has been detailed over the last few weeks
Great manual to learn in
Has cost me NOTHING but services and a bit of front suspension work which was a common fault.
Selling cause I'm sick of having two cars and the skyline wins.
Never done hand brakies or any of that crap, drove it for what it is, a reliable commuter that gets you to and from a b and c.
Price is neg but I don't want any 1000 bids or any you can buy a SICKKKKKK r32 bucket for half the price.
Camrys of this model with100,000kms more go for 500 dollars less with none of the added extras.
Extras include:
Remote central locking, alarm system, 4 6" speakers, Sony cd player head unit, 17" alloys, toe bar, power steering and aircon.
Swing me a PM or email via car sales.
I want it gone by 28th of this month so I don't need to insure it again. (keep that in min with the neg ;)
Revised price.
A r32 is the same age and people are asking 8-13 grand for gtst buckets because it goes vvvmmmmm tu tu tu.
This is has low kms and is reliable as. I based my price on the market of these cars and have since revised the price to the same as others with over 200,xxxkms on it.
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
