I recently purchased a 1993 R33 GTS N/A Skyline and have a few questions.
1. Did the 1993 R33's come out with dual airbags?
2. Did they come out with HICAS?
3. Did they come out with ABS
Mine has all of that but my mate has the same model and none of it and his never heard of a S1 having any of it.
Cheers.
https://www.sau.com.au/forums/topic/387601-r33-skyline-gts/
Cheers.
1. No
2. No
3. Not sure
Post pics.
https://www.sau.com.au/forums/topic/387601-r33-skyline-gts/#findComment-6179932
Dash/Inside: Dual Airbags/no S2 white dash or other accessories
HICAS/ABS/Airbags on Dash
Outside of the car
Rear Diff/HICAS motor
Manufacture plate
If your wondering I know him irl ...
Edited by Brendonams
https://www.sau.com.au/forums/topic/387601-r33-skyline-gts/#findComment-6179954
im not sure on the dual airbags, but s1's definetly had a drivers airbag option
yes they definetly did come with hicas, atleast mine did
and yes they did have an optional abs
i also have a 93 r33 gts although i dont have abs or bags, just hicas
https://www.sau.com.au/forums/topic/387601-r33-skyline-gts/#findComment-6181166
I have a Series 1 with the same air bag steering wheel and it also has passangers air bag, abs and hicas (although it is a GTS-T).
The best option would be to provide a picture of the blue build plate from the firewall so I can run it through the "Nissan Fast" program to see what options the car had from the factory.
https://www.sau.com.au/forums/topic/387601-r33-skyline-gts/#findComment-6188038
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
