Hi gents, here is the prob.. Bought new r33 gtr coil packs for my motor which is about ready to fire but came to find plug doesn't fit on harness. Closer look reveals I may running r32 loom, coils and igniter.
I threw splitfire box but don't remember seeing the Pinout! I can make plugs fit by shaving the coilpack receiving end just a bit but will need to repin plugs on my loom.
On my packs from left to right, - + signal
On splitfire, IB, G +
Can't afford to fry $600 worth of plugs.
Please HELP!!! Tks to all in advance
Thank you mark!! So it appears I'm running r32 coils and igniter on my r33 motor, darn Japan junkyards!!
Since I don't have any OEM r33 gtr coil packs, are IB, + G
factory markings?? Hence Splitfire using the same marks on their product?
Thank you again!
Or maybe I have Series 1 loom?? And series 2 coil packs is what i bought??
You may want to look into this some more as S2 coils have the ignitor built into the coils, where as the S1 coils need an ignitor pack.
I was going to say look at the box, but you already turfed it lol, do you have a receipt for them still, your looking for a part number aomething like, SF-DIS-XXX, where the xxx is a number.
all are factory markings, they just changed symbols for some reason when moving from 32 to 33
i bought S2's for sure.. i checked the part # so now they will not work.. as I have S1.. classic!!
if your handy with a soldering iron, you may be able to use those s2 coilpacks. in 32 and 33s1 the ecu sends power to the ignitor which allows the coil to ground itself (makes a spark). if you take the power that was meant to be going to the ignitor pack and route it directly to the coilpack, you may have solved your problem
Edited by markdem
As mentioned by RRob, the R32 GTR & R33 GTR require the SplitFire SF-DIS-001s, if you have a set of SplitFire SF-DIS-005s don't try to modify them as using them will likely damage your ECU.
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
