Hi Guys
I have a gtr imported under the 15 year rule a while ago.
This has been off the road for years and was last registered in NSW november 2008. I have put it back together and it is nearing the stage of getting registered again.
I need tyres and a quieter exhaust made up which i can obviously organise pretty quickly.
I would like to know if i can just drive it to an exhaust place or if i need to trailer it around. I would also like advice on wether or not i need an engineers cert as there are no compliance papers, but the old rego sticker is on the window! Any advice would be good.
Thanks in advance
https://www.sau.com.au/forums/topic/387617-re-registering-an-89-import/
From memory when Jenna re-registered her car in nsw she needed import papers, old Vic rego papers, receipt for purchase of vehicle, receipt for purchase of replacement engine, signed confirmation of engine installation from mechanic (including the new engine number) and obviously blue slip and CTP.
Hers was an 89 import previously registered in Vic but rego had lapsed... call up the RTA and ask as well because this was 3 years ago.
It's a fark load of shit and you don't want to get there, wait an hour then find out you missed something!!!
on the phone just then, girl said i need a blue slip, ctp, and thats it.
wtf. I'm on hold now as i convinced her there must be something else...
She has now said although it was registered before in nsw i will need the import approval which of course is with the original owner somewhere. ><
Apparently i can ring and get it reissued.
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
