Unfortunately due to bad sales in winter my business is having some short term cash-flow issues... Which means my Stagea may have to go.
Which sux as I will surely buy another in a few months time when things are not so tight!
I have had a quick look on the forums and car sales etc, but don't know what a fair price for my car would be.
Realistically I know I will never get back what I have put in. But what would be a fair list price for this:
It has been babied, garaged and serviced every 5,000 with the best oils etc and is in exceptional condition.
2001 M35 250 RS with Factory Aero Kit (Inc the wing!)
Odo - 112k
Modifications:
Kakimoto R Exhaust - cat back
BC Coil-overs
Selby adjustable Sway Bars
Apexi SAFC II
Pro-S tuned ECU
Enkei GTC-01 19x8.5 +22 rims
2006 350Z Track Brembos with DBA Slotted front rotors
Hybrid Front mount intercooler kit
HID Headlights
K&N panel air filter
Panasonic head unit
Reverse Camera
Ipod connectivity
Pictures: Big thanks to Chris (Spoolin) for his mad camera skills!
https://www.sau.com.au/forums/topic/387635-eoi-might-have-to-sell/
sweet stag, im looking in a few months but not yet:( ive been looking and doing research on prices and mods etc and yeah i think around the 17 mark is on the ball. Thats what id be happy to pay when the time comes with one like that, only prob is no sunroof which might turn a few people off. i do like yours better with that interior rather than the leather.
hope sale goes well. maybe ill go to bank and see if i can get cash now
I'm certainly interested also if its around the $17k mark and will have finance in place in a couple of weeks, or worst case end of month.
Have you done any maintenance on the turbo or dump pipe as I’ve read that these are susceptible to failure around the 100k km mark?
But again, certainly keen and will be in contact in a couple of weeks if you decide to go ahead with the sale.
Given the obvious interest in the vehicle, Id say $17k would be undervaluing it. However at such a price it looks like you'd be ensured a fast sale. Hold on to it if you can mate, its obvious you've put a lot of work in to it!
With what little I know of M35s, I'd say $17k would be what you ask, as is, if you needed a quick sale.
Obviously you know your situation better than I, but do the sums carefully. Is liquidating the Stag the most cost effective way to inject some cash into your business? You are no doubt going to end up way out of pocket as you won't get back nearly what you have put into it. Add in the costs of selling and then one day buying another and I'm willing to predict there are much more cost effective ways to source some cash, such as a Line of Credit or Personal Finance or something to that effect. Worst case is you can always sell the Stag later if things do not pick up and you need to cover the LoC.
A personal loan will cost you principal + say 10% if it takes you a year to square it off. That's $1000. Are you going to lose more than that by selling the Stag? I'll predict yes, by a lot.
But, again, you obviously know your situation much, much better than I (as I know nothing about your individual circumstance).
Such a shame Benny; yours is my favourite NM35.:wub:
Except for mine.:D
Is there no other alternative? I don't need a new bike, or any sexy bits right now, so I can't help you that way either.:/
Perhaps a merciless internet spam advertising campaign would help; I'm sure it works with Viagra...
Thanks for all the kind words guys!
The Pro S is a tuned ECU as iamhe77 said, no speed limit, higher rev limit, higher boost and timing changes too I believe.
At the moment its not 100% yet that I will have to sell this as I am working on alternative finance avenues, but should push come to shove I wanted to know what would be a fair price for my beloved Stagea.
Aaron, check his sig... mountain bike gear! http://www.ribbed.com.au/
Doh!
Thanks >_<
Myself and a few of my friends are in the market for new bikes. I shall check it out.
Unfortunately a few others have already bought bikes recently - would have been good to direct them to Ribbed as they all spent between $2k and $5k.
Edited by Cowboy1600
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
