Which makes it sound more like a flow issue, and not exhaust side as that tends to send temps up and hence detonate.
Which leaves valves, intake, leaks??, turbo, cam timing etc.
yep... 3.5" was made as 3" would not flow enough for 350kw+ so thats fine
turbos are in good nick...
cam timing... shouldnt be an issue if cams/cam gears are both standard??
leaks have been found and fixed
intake is new as we had to remove the AFMs due to the MAF less tune
which leaves valves I guess??
"peak power right now is at 6300... car just starts struggling to breath and loses power"
Sounds like an exact thing i had.. Drop a set of Tomei TypeB 9.15mm in. Ignore what everyone says about running standard cams and try again and you won't live to regret.
Everyone is always talking highly of Unigroup but i find the car's he tunes runs quite low power and they are only in RWD/2WD? Too safe of a tune perhaps? Who knows...
Don't think it's that much of a mystery mate.
I'd say it's due to the fact yavuz doesn't feed customers bullshit dyno graphs to keep them happy.
Get a figure from ur tuner then take it to Unigroup and get a real read out
can you please provide further details of your situation?? even the tuner said standard cams are perfect for -9s
yeh Yavuz only has a 2 wheel dyno so readings are in RWD... he does tune them to last so they might be slightly lower in power perhaps...
lol.. if you have a standard motor and you want to make 380-390kw i dont think especially with gt-ss sized turbos. i just think its a little too ambitious but thats just my opinion and from experience. I'd say 350-360max on eflex with a set of cams?
The problem i had was i couldnt get power above 6000rpm, put a set of cams in on a STANDARD motor and it brought the mid-top end straight up. You can feel the difference for the midrange-topend power.
With the 2wd readings, it should be higher than in 4wd. His readings are definitely lower, but as i said, who knows, everyone modifies their head different and it could just be that or as i said it could be his tuning too safely.
lol.. did i say feed customers bullshit dyno graphs? all i said that he could be tuning his cars too safely?
Get a figure from you tuner and take it to unigroup to get a real read out? lol seriously dont be so ignorant. Each to their own then, but its just my opinion on what i've seen from other peoples dyno graphs tuned by unigroup :)
"Everyone is always talking highly of Unigroup but i find the car's he tunes runs quite low power and they are only in RWD/2WD?"
So you find that your not impressed with Yavuz's work? you look at a dyno graph power reading and becasue u think its a bit low you wonder why everyone talks so highly of him? dont be so ignorant
"Too safe of a tune perhaps?"
i realise this is a question, im sure Yavuz knows what "too safe" is
Biased much? Thats what i mean about being ignorant is because you are like the rest of the sheep on here and i can tell from your response. I am just trying to say that there are other tuners out there. E.g. JEM, Powertune, Unique Automotive. Not necessarily everyone on SAU has to go Unigroup though a lot of people on this forum goes to him because of people like you and N1GTR whom is always putting forward recommendations. Although those that do are happy with their work and i presume you are one of those guys who are?
In saying that, I am just saying i feel he tunes perhaps a little safe and thats why the power readings is a bit low for the mods on the cars he tunes. Thats all, nothing about him being a crap tuner or nothing. You put forward your recommendation and opinion and i gave mine.
Yavuz the smartest tuner i have met.
An engine will only make what it can make. But then different dyno's is like apples and oranges. My GTR made 296kw of yavuz's dyno and 296kw on the mainline i use.
Ive had plenty if customers come from other shops with really high dyno readouts, and first run on the mainline are
Down 30kw.
On 98 ron most engines are knock limited, so u can only push a motor to det then add a safety margin. Basically.
Well I made 340rwkw, 19psi on -9s on PULP
Stock cams.
Put the -5s on, 365rwkw @ 19psi
Both above 6000rpm, was 7500rpm or so.
No so sure stock cams are necessarily the issue if the cam gears are set right.
Stock cams.
yep
something else is a foot!
I wanted full boost before 4k and was going to get cam gears but was assured i wouldnt need em.. and he did pull it off.. 25psi by 4k is pretty awesome..
They would have tried around 20psi... Id say it would have been around 310kw.. will check tomorrow
What dumps are you running??
When my engine was std (just cam gears) I was making 335kw at 22psi With my -9s
So I don't think springs are the issue there is a restriction somewhere
If you have std intercooler maybe check if there is pressure dropping through it, maybe in need of a clean??
As the std cooler is fine for the application
Never understood this. Cam gears are the best thing you can do apart from putting fuel in the car! (providing the guy tuning it knows what he is doing and spends the time setting them up)
standard dumps
your springs were working fine... mine appear to be screwed
the bolt ons have been check, checked again then checked one more time... he has eliminated them as the issue
yeh i dont think PT use them very often... im still very happy with the response.. on paper at least... will drive it tomorrow
    • Hi guys looking for a r33 Gtst stock exhaust asap in Melbourne have $$ waiting thanks
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
