Word of mouth is the most powerful tool for businesses. If everyone comes out of his shop and starts to recommend him, then he must be doing something right, no?
And what about those that dont recommend him coming out of his workshop? I had two PMs about it? 'everyone' ... lol
Sorry I knew I shouldnt have said everyone. I forget that I'm speaking publicly sometimes.
None the less, the only way to find out is to try for yourself.
I think we're all grown ups here, make your own decision and don't get all emotional if a workshops name gets dropped in a conversation. It's their decision isn't it? Not yours.
Besides if you were to substitute unigroup with workshop that you like, then I'm sure you'll be backing them up. And someone will come out and say "nah x workshop is better".
This is basically politics. Pointless to discuss.
I wanted full boost before 4k and was going to get cam gears but was assured i wouldnt need em.. and he did pull it off.. 25psi by 4k is pretty awesome..
They would have tried around 20psi... Id say it would have been around 310kw.. will check tomorrow
25psi at 4k is pretty impressive. I dont think i've seen anyone here hit that level of boost at 4k, normally would be 20-22psi and that would be with adj cam gears.
I personally was able to get about 18psi at 4k (stock gears) but that was with no boost source to the actuators(8.8psi) and they had a reasonable amount of preload on them so i doubt they were being pushed open.
Have a boost plot against rpm?
Not sure now.
I bought my 5 speed with big input shaft for $2,760 delivered from greenline 4 years ago. You will need all the Series 3 internals to run it.
Make sure you buy the billet centre plate from OS.
Not sure now.
That is pritty cheap. I wish they didnt come with such tall ratios
They can either work for or against you. At Huntley it really works. You just need a bigger engine to turn the cogs. *hint hint, nudge nudge* ;)
    • Hi guys looking for a r33 Gtst stock exhaust asap in Melbourne have $$ waiting thanks
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
