lol now now fellas
this was suppose to be 10k build... that 10k has already been spent and ill ive ended up with is 320kw and another broken box haha
ah well... it is what it is...
now the issue is what to do...
get another 33 box (which I can get for $500) + plus install and whack that in and drive like a pussy for the rest of my life
or fork out 4-5k for a OS/PPG gearset
cost vs benefit really
How many boxes will you do till you put a 'big box'
In? If you do 4, you're half way there and are still stuck with a standard box. You shouldn't be busting them with the power you have UNLESS you have no mechanical sympathy!
I say do it and do it properly. Costs less in the long run!
  On 04/02/2012 at 4:35 AM, Piggaz said:
They can either work for or against you. At Huntley it really works. You just need a bigger engine to turn the cogs. *hint hint, nudge nudge* ;)
I got something in the pipe line.... hahaha a few more months mate
  On 04/02/2012 at 4:57 AM, usmair said:
http://www.rhdjapan.com/os-giken-close-gear-kit-3-speed-nissan-rb26dett-input-shaft-50042
its 1st, 2nd and 3rd that cop the abuse so it would be perfect right?
thoughts?
Well that would be the same as mine as I decided to go for OEM 5th gear for highway.
That's about 3K? Try greenline.
What clutch?
That is often the cause of broken boxes.
I've got 360rwkw or so, and I can launch from 8000rpm with sticky tyres, smack second - no problems. Even flat changing 3rd-4th wasn't a problem... Run after run.
Anyone @ Drag Battle can verify :)
  On 04/02/2012 at 8:59 AM, Rolls said:
Are you crunching gears or flat shifting with the clutch half out or something?
lol i think i just got into the moment and tried to slap it in 2nd... clutch possibly may not have been all in the way :whistling:
  On 04/02/2012 at 4:17 AM, Piggaz said:
Not sure now.
I bought my 5 speed with big input shaft for $2,760 delivered from greenline 4 years ago. You will need all the Series 3 internals to run it.
Make sure you buy the billet centre plate from OS.
I have a spare OSG billet centre plate here ;)
Or a Trust/Quaife H-pattern dog box. :whistling:
  On 04/02/2012 at 1:20 PM, fatz said:
changing gears easier would save you 5k
cost benefit ratio for you being nicer to your car is very high, and would allow you to be quicker at the strip.... as you would get to the end
lol
yeah but fatz he wants to chirp second
lol
:laugh:
