Got some bad news
Car is struggling to make power
Made 317kw at 22psi on e85
They are going to run some tests on it tomorrow to see what the problem is
Seems about right?
i'm making 372rwkw on 24-25psi on E85 with -5's
the only restriction would be the turbo's
E85 won't make turbo's automatically make 50rwkw more top end that it would on PULP.
E85 gains are in the midrange, so you might've only made 317kw but the midrange would be a lot stronger than most others in PULP
ok found the problem! they did a smoke test and found that one of the gasket/hoses on the intake side under the plenum is cracked and is leaking pressure
not the motor :) but still a 3/4 day job to take it out and fix it... labour is going to bend me over! but it should make good power once its sorted!
Seems about right?
Seems a little low. 372 at 25 on E85
Seems about right?
317kw on e85 is shocking... clearly something is up with that sort of power on -9s
we've found the leak... going to fix it then try again!
i probably should get a smoke test done on my GTR.
that's the only thing that i havent tested it for.
i had issues with the idle searching, then i had the tuner block off the hoses going to the idle control valve under the plenum and i picked up another 1.5 of boost on the same settings.
i think all my hoses probably havent been replaced yet, and its an 89 GTR so pretty old hoses.
yeh would def get one done to get the piece of mind that there are no leaks
and yes 375kw @ 25psi with -5s is sorta low... should be nudging the 400 mark
where are the common places for leaks when a smoke test is done?
all gaskets and silicon joiners. I had the sandwidge gasket between my intake manifold leaking (rb25) never would have found it otherwise, gained 4psi just fixing that, had to turn the boost down as it started to detonate.
I've still got std cams, which might be holding it back a little?
will be putting some type B poncams in soon, and will get smoke test done.
hopefully be nudging 400kw if everything is right.
Cams wont be holding you back. I've got 360rwkw on 19psi and PULP with -5s
20-22psi will see 380rwkw on PULP (stock cams, on 2 separate cars down here)
Others using E85 have hit 400-420rwkw.
There are other issues with your set-up
what kind of boost are we talking?
from 10 to 14 or something like 22 - 26psi??
Well hopefully a smoke test can show if there are any leaks anywhere and when the cams go in the clearances will be checked so that should hopefully rule out anything to do with the head?
it very may well be a leak somewhere.
the car made less power when i changed my intercooler piping.
i made 350kw on 21psi on PULP then changed my piping because the stock one blew off and split. replaced it with a silicone one and it made 315-320kw on 21psi.
so it very well may be a leak somewhere in the I/C piping? maybe just enough to be bleeding out a slight amount of air?
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
