he is such a good guy... didnt think he would still remember me
told him the issue and he did say the problem I have is one that could occur due to valves.. although he did say that valve problems are pretty rare
he also said he had a method of determining whether it is actually the valves without opening the head!
so will def be getting the car looked over by him (not sure if i should tell PT though)
was going to call him tomorrow but he called me lol... was very impressed! should have just gone to him again lol
Edited by usmair
I might have misinterpreted him
i think he meant due to the cost involved in changing springs... it might be financially better to 'do' the head (if i wanted to) seeing as we're spending $ on labour regardless
I can understand this, a full reco'd head might be better value than doing just the springs on your head. Though you'd want to make sure it was a reputable company that supplied it.
Usually valve float occurs at a resonant point in the rev range meaning that the power falls away momentarily. You usually see the mixtures do weird things at that point as the exhaust valve stays open longer.
If your exhaust back pressure is high you will usually float the exhaust valve on a turbocharged car given the profiling of the inlet is similar to the exh.
Does the power stay on higher at lower boost levels?
Tuner said power isnt falling momentarily... it just starts to lose power consistently after 6300RPM... its not like it temporarily loses power then jumps back up :S
the back pressue shouldnt be an issue... its got big front pipes and a 3.5" exhaust
the power is staying similar thought! it made 317kw on 22 psi with a boost leak under the plenum from a gasket
what does that suggest?? (sorry complete noob here)
he didnt mention anything about knocking... just seems to be stuck at 320kw
Which makes it sound more like a flow issue, and not exhaust side as that tends to send temps up and hence detonate.
Which leaves valves, intake, leaks??, turbo, cam timing etc.
"peak power right now is at 6300... car just starts struggling to breath and loses power"
Sounds like an exact thing i had.. Drop a set of Tomei TypeB 9.15mm in. Ignore what everyone says about running standard cams and try again and you won't live to regret.
Everyone is always talking highly of Unigroup but i find the car's he tunes runs quite low power and they are only in RWD/2WD? Too safe of a tune perhaps? Who knows...
can you please provide further details of your situation?? even the tuner said standard cams are perfect for -9s
yeh Yavuz only has a 2 wheel dyno so readings are in RWD... he does tune them to last so they might be slightly lower in power perhaps...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
