Word of mouth is the most powerful tool for businesses. If everyone comes out of his shop and starts to recommend him, then he must be doing something right, no?
And what about those that dont recommend him coming out of his workshop? I had two PMs about it? 'everyone' ... lol
Sorry I knew I shouldnt have said everyone. I forget that I'm speaking publicly sometimes.
None the less, the only way to find out is to try for yourself.
I think we're all grown ups here, make your own decision and don't get all emotional if a workshops name gets dropped in a conversation. It's their decision isn't it? Not yours.
Besides if you were to substitute unigroup with workshop that you like, then I'm sure you'll be backing them up. And someone will come out and say "nah x workshop is better".
This is basically politics. Pointless to discuss.
I wanted full boost before 4k and was going to get cam gears but was assured i wouldnt need em.. and he did pull it off.. 25psi by 4k is pretty awesome..
They would have tried around 20psi... Id say it would have been around 310kw.. will check tomorrow
25psi at 4k is pretty impressive. I dont think i've seen anyone here hit that level of boost at 4k, normally would be 20-22psi and that would be with adj cam gears.
I personally was able to get about 18psi at 4k (stock gears) but that was with no boost source to the actuators(8.8psi) and they had a reasonable amount of preload on them so i doubt they were being pushed open.
Have a boost plot against rpm?
Not sure now.
I bought my 5 speed with big input shaft for $2,760 delivered from greenline 4 years ago. You will need all the Series 3 internals to run it.
Make sure you buy the billet centre plate from OS.
Not sure now.
That is pritty cheap. I wish they didnt come with such tall ratios
They can either work for or against you. At Huntley it really works. You just need a bigger engine to turn the cogs. *hint hint, nudge nudge* ;)
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
