Hey All,
I'm sure a number of you have been in this situation before so I figured I would ask here first before I start chasing mechanics and RWC testers.
Got pulled up by Mr Plod yesterday and he defected me for the following:
  • Ground Clearance - The flange on the rear muffler is a touch too low. Should be able to sort this out with my exhaust guy.
  • Tyre Placard - This is missing. I believe I can buy one from Nissan. Can anyone confirm this?
  • Engine Bay Mods - This is the harsh one. There has been two holes cut for the front mount cooler. The cop wrote this one up because he 'believed' that these holes weren't factory. Im not sure if they are or not. The note says to "Get holes in body work VASS certified." I assume that means engineers :( Anyone know any other way around this? (Pics attached). One is under the battery box, the other is more oval shaped infront of the airbox, is that one standard?
Battery Box Side
Airbox Side
Any help here would be appreciated. I'm happy to get all these things properly but I guess im just trying to get options that I may not have thought of.
Cheers,
Glyn
https://www.sau.com.au/forums/topic/387655-another-defect-thread/
Is it a R32 gts-t?
If so - Both holes can be "made" legal, as they are both in the wrong. You just get a VASS and it's over and done with forever ($550).
Honestly that is the only way to do it as well. Repairing it and removing the parts will just cost you more in the long run.
Pretty standard issue that most people simply overlook when modding cars or buying modded ones.
If it's not a R32... Well... I hope for your sake it is...
Regarding the holes, ive seen these on an S13 and it passed engineers, same reason for a defect http://www.boostcruising.com.au/forums/index.php?showtopic=624808 not sure about the skylines. If its good for one, it should be good for the other!
Sanjay Bhide(VASS No.1021)
Autoteam Consultants Pty Ltd
6 Mosman Close
0402 407 839
Thats the engineer who did the S13. Maybe give him a try.
tire placards from nissan are in japanese, your best of going to someone who compliances cars as they would put the AUS stickers on
Isn't it just easier to type one up in Word and just print it out? Did that a couple times, just taped it on neatly, never had a second look.
Harsh; especially about the placard >_<
What landed you into being pulled over and given the full treatment? Maybe just the exhaust?
I had seen him pull up a VL while I was in the shops. When I left and went to the servo, he waited for me to pull out and did the deed. I would say it was the zorst from behind looks really low. I'll get it all tucked up before I put it back on this time around. it was either that or the custom number plates I had made up lol.
There is one in Braeside, Enkelmen or something close to that (it's on the VicRoads website).
They are reasonably priced and straight down the line. Taken my own car there as have many mates.
So have I, I'd recommend them.
http://www.enkelman.com.au/
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
