hi guys,
Only reason im selling is i need money to get a 4x4 for my baby.
The car has just recently run out of rego and has done 150xxx ks and had a new paint job in the middle of 2011.
The goodies,
*Full Uras body kit.
*Drift Teks 17x9's i think....they stick out my stock guards a fair bit.
*Fully adjustable ISC coil overs.
*Cusco front strut bar.
*3"inch full exhaust system.
*After FMIC (unknown brand).
*z32 AFM
*Digital Drift gauge cluster on A-pillar, boost and oil pressure.
*Turbo Timer.
Pics
I'm asking 10k ono
For serious buyers you can sms anytime or call me after 2:30pm on 0402227842.
https://www.sau.com.au/forums/topic/387671-clean-89-maroon-cefiro-rb20det/
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
