Hey guys,
Wanna change my brake fluid today as its never been done.
Been investigating all the threads and think I'll be going for the Caltex Gp600 Dot 4.
I'll grab myself a bleeder kit and give it a red hot go.
Any tips on what to do cause i have no idea and can't find any DIY's on it?
Do any wheels need removing?
How many litres needed for an R33 GTST?
And not sure about the actual bleed nipple, as in what to do with it?
(a half turn or something)
Any info appreciated.
Thanks...Birnie :headspin:
https://www.sau.com.au/forums/topic/38768-how-to-change-brake-fluid/
you will be needing 2 bottle for a complete brake flush/bleed.
you HAVE to start working from the rear left -> rear right -> front left -> front right. Reason being that you wanna flush out all the old fluid and the only way to do that is to start flushing @ the wheel furthest from the brake cylinder..
always make sure that you do NOT empty out the brake cylinder while pumping out the old fluid. get it refill constantly with the new oil.
i did mine with the wheels on and with a half turn as well. make sure you got some degreaser or a rag on standby becos the fluid will leak onto your rims/tyres. Its very corrosive.
hope that helps.
yeah, I take the wheels off coz its a bit easier to get at the nipple. Check fluid after each wheel like GenesisR32 said.
Keep bleeding until you see the new fluid colour at the caliper and there is no bubbles
Also, if you have ABS you need to bleed the ABS unit as well.
And, since you couldn't find an FAQ thread, write one when you've done it :P
Thanks guys!
I'd lile to get some FAQs up there but will do it when i get my hands on a digital camera to make it that much better. (the oil changing one was excellent!)
What you guys wrote is definately a good start.
I nearly went ahead and did it today, but didn't thankfully.
I installed my SAFC instead. Looks sooooo cool even though it's not doing anything yet.
One wire to go.....the fuel mixture one.
The throttle display is great for a giggle. :P
Search words
replace replacing brake fluid change changing air bubble bubbles
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
