Basic question really, for my 1995 GTSt I need a new set of discs and pads. Does anyone know how much it will cost to replace all the discs with new items? Basically I have been told this will cost around $1K, for that price I might as well go all out and buy a second hand set of Brembos. Any advice?
https://www.sau.com.au/forums/topic/38769-new-brakes/
hey mspec, check out the DBA rotors www.dba.com.au, they are better and cheaper than the nissan items. Not sure who sells em in Melbourne, Racebrakes in Sydney have a discount for SAU members
Pads? Bendix Ultimates, about 200 for the set. More details in the FAQ http://www.skylinesaustralia.com/forums/sh...ead.php?t=17760
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-786271
Thanx for the info, I remember seeing the DBA disks in an import mag a while back, I was trying to find the mag :) I cant find any prices online, but they are available from pretty much anywhere; Autobarn, Bursons, Repco, Supercheap and so on! My last set of pads were Bendix and they did the job well. They also do not cost much which I am sure you are aware of. Anyway thanx again for the info mate!
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-786409
You mean slotted & cross-drilled? (suitable for street driving only, not track work).
Urmm not sure maybe an extra $100 or so... Buster has them on his car.
Edit: I got my DBA4000 Slotted Rotors in a group buy from on here for ~$845 around 12mths ago.
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-786428
To be honest im not sure what the difference is between the Club-Spec 4000 and the 'longlife' rotors, I believe the Club-Spec 4000 is the newer model as they are only about 15mths old where as the 'Longlife' appear to be about 4yrs old.
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-786441
Okay fair enough, I will find out on Monday when I go price hunting :) Just doing a little extra research before hand. By the way are you guys quoting for just the front disks or all round?
Uniqueautosports is asking $795.00 Per Pair of R33 GTR DBA 4000 Series Front Brake Rotors.
http://www.uniqueautosports.com/pricelists...%20steering.htm
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-786446
Don’t recon the DBA 4000 Series are worth it. Got a quote today down at Autobarn, they recon the front are about $540ish each and the rears are about $450ish. At this price its cheaper to import a good condition set of Brembo brakes. I have used these on my GTSt in the past and there awesome, the last set was sold but I think I will get a new set. For about $2K you can get a full set of GTR (Brembo) discs, calipers and pads, so this is what I will do. Anyway guys thanx for the help.
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-787028
MSPEC - I am in the same position as you, and am going to have my brakes done on Monday. I can answer some of your questions:
1.- DBA Long life Series and DBA 4000 Club-Spec Series are not the same rotors.
2.-changing the standard rotor for a drilled/slotted DBA one with the same calipers and pads will not really improve braking that much, but may reduce brake fade to some extent under severe braking conditions. - Changing to good pads will improve braking more than changing the rotors. (rotors will help reduce brake fade)
3.-How wide are your current rotors? the DBA specs are incorrect and state that the minimum thickness is 30mm. (It should be 28mm - you can check with Nissan to verify this).
In my case this now means I can keep the standard rotors for a little bit longer and spend the money on machining and pads.
The prices I gathered indicate that DBA front rotors cost $850 fitted, and standard ones (from nissan) were cheeper. Rear disc rotors were about $500 from DBA.
I believe there is a shortage of DBA rotors at the moment for R33's as they all list them but have trouble locating a pair. I also found out that some GTR rotors are almost identical to GTSt rotors, but you can get some useful information from Racebrakes in Sydney.
https://www.sau.com.au/forums/topic/38769-new-brakes/#findComment-788274
