Hi All,
Who wants an international standard race track and motorsports facility at Avalon? :banana:
The debate is hotting up and the more public support this gets, the more likely the Government and private business is to fund it.
Some potential plans for the track and complex have been drawn up and they look awesome - check them out at this Facebook page and be sure to 'Like it' to show your support.
Cheers
Dave
http://www.facebook.com/pages/Race-Track-at-Avalon/315173515181213
https://www.sau.com.au/forums/topic/387736-avalon-motorsport-complex/
Where is the debate exactly?
I only ask as the FB page has only "7" likes... Not much of a debate.
Umm, I didn't say anything about the debate being on the Facebook page - I just said this was where the information on the track was. The general 'public debate' is what I was referring to.
Go easy on me - I'm just trying to create a bit of public support and a space for people to share ideas - the page has only been live for two hours, so 7 likes isn't bad so far! :thumbsup:
is this the new Motorvate melbourne crowd?
ie wanting to build a track/drag strip at avalon either with gov support, bobjane/lindsay fox or combo?
ie the one that has been going for 5-6 years now???
admittedly they are more drag orientated now but yeah?
http://www.motorvatemelbourne.com/cause.html
this "new" one who is behind it?
sponsors, major players/organizers?
race teams backing you?
little more info if you want our support.
else we could just create a
lets make prinny highway a street circuit...
don't get me wrong I'm all for more tracks in vic and the better quality, but want a bit more info b4 I throw my support
Also curious the link SAU has with this??
Yeah, fair enough.
To be clear, SAU has no links with this page and nor does any other organization - it's just an attempt to draw together the information that is out there and create some awareness about the proposals for the circuit. Nothing more than that.
Have a look and if you like it, 'Like' it, if you don't then don't.
Cheers
Dave
(Apologies that the SAU logo image was left over from developing the page: it has been removed now. The SAU track images were an idea that the club could sell/give as decals to people who participated in track days and were not related to that page)
i reckon something on the motorkhana scale would be a good thing to try and get off the ground. Small enough that it would be feasible, and then once that is shown to be a sucess, you leverage that to push for a more comprehensive facility closer to urban centres.
Sounds like another Motorvate..... i.e. fail
I dunno though, with the backing of CAMS this one may have a bit more behind it, but I'd imagine the $200m might be a problem given that the state Government are broke. It just needs someone in there who can visualise the potential and realise that there is a gap in the list of world class sporting venues in Melbourne.
We live in hope!
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
