Hey guys, I've done a search on this problem with similar posts but not quite the same symptoms so I thought I'd make a new one.
I've had indicator problems for a few weeks, on and off, currently the left indicator works fine but the right doesn't. Here are some symptoms:
  • Left indicator works fine, right doesn't
  • Disconnected front and rear looms to lights to try and narrow it down to an earth somewhere with no luck
  • Currently got a 20amp fuse to prevent fuse from blowing, makes high pitched noise when using right indicator
  • Got under the dash to find the relay switch, not sure what I was looking for but I following the clicking to a black box and it was really hot when using right indicator, located directly under steering wheel, above fuse box.
  • The dash indicator light (for right only) also doesn't work
Does this look like the flasher can is dodgey? Does it make sense that left works but right doesn't? If I rip it out, is it just a case of getting a new one, and where would you go to get one?
Any comments would be highly appreciative.
https://www.sau.com.au/forums/topic/387752-right-indicator-problem/
Hey guys, OK so I got under and pulled out the indicator replay switch, and pulled it apart.
Here are some images of what I found. You can clearly see some burnt bits on the solder points on the bottom, and on the metal hook/staple looking thing on the other side.
My question is - is this the cause of the right indicator to screw up? Or is this the result of a short somewhere else which has caused the switch to burn? (Keep in mind I put a 20amp fuse in the fuse box)
Reason I ask is, I don't want to keep on destroying new relay switches!
Edited by Everlong-S13
  • 1 month later...
it could be a bad contact in you indicator switch off the steering coloum. had a similar problem in a patrol not long ago. cleaned it up and it hasnt played up yet. im not sure about in the skyline but be careful of springs if you decide to pull it apart as they can go flying and also be quite a difficult job putting it back together.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
