  • Replies 46
Do they require the usual battery and tow hook stickers for these days?
Also don't mention anything about fire extinguishers.
I attended the Christmas Tampered day and no sticker or fire extinguisher was needed although I had one installed just in case.
I'll see you guys there.
Edited by adam-__-
trix if you can get to south melb tomorrow you can borrow one of mine.
else if there a 6 pack in it I can be there by scruit time.....
tampered have....generous.. checks.
nohthing loose,
4 tyres
helmet
your good
not ext needed
no stickers
i'll turn up as a spectator/camera work for the day
atm no speed for me....
nohthing loose,
4 tyre
helmet
your good
not ext needed
no stickers
Hey man thanks a lot,
Deffinately a 6pack in it for ya and I'll still pick it up if u want? Or I'll meet you there in the morning?
if you want to pick up st melb tommorrow send me a PM and I'll give you the address and a number to call.
if u wan to do thurs morning just let me know and can meet u there.
damn more and more wanting to come out and play...
Oh If your coming Thursday I'll just meet u there or come to the pre meet at wallan bp I'll be there with everyone at 6. If your not coming ill just come get it tomorrow. Also what drinks would u like?
Thanks Again,
Dion
Guest
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
