Anything for this Friday night? (20/9)
  • Replies 47
Guest | hype^ |
yeh i 'should' have my car bak on fri too!!
finger crossed!!!!!
so yeh hopefully we can all organise something..
maybe find some more bogans to chase!! (hence we need minh and 'the boot' aka dave there) :lol:
yeh chris i saw ur old car at the carpark near hills m/s today...
cant believe ya sold it.. with the plates too! :eek:
dont go there girlfriend!
:D
Originally posted by GTR-80Y
Or lets all go for a piss up!?
...but... that would mean no car, and we can't have that now can we.
i'm in the city on fri night having dinner with bunch of ppl and will prolly start drinking then. if you are keen you got my number.
ryan has a point though. there's some very nice roads heading up to wollongong and just past it around the coast. some very nice lookouts and whatnot. makes for a nice change from the usual north run but since most of you live out that way i guess we always end up doing the same run. but i don't own a car so :D it's not my place to say anything.
Guest | hype^ |
i tell ya what if my car isnt ready im gonna have a fit!!!
ryan i can take ya even if my g/f comes.. (incase my car brakes down :lol:)
if the car aint ready... i dont think im gonna be enough of a a$$-whole to whore 3 weeks in a row,, but who knows stranger things have happened! :lol:
btw if my car is ready.. any1 have a spare radio i can borrow? its kinda lonly without one.. :uh-huh:
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
