So I was going to go to a car audio specialist in Vic and get the work done but have decided I would roll up my sleeves and give it a go myself. The main reason I wanted the help of the experts was their assistance in piecing together a nice setup...but after a few poeple recently molesting my new car I would just rather do it myself.
So peoples thoughts on these components:
Deck:
Pioneer DEH-8350SD
http://www.pioneer.com.au/au/products/22/121/61/DEH-8350SD/index.html
Amps:
Either of the following 5 channel L5.1110 - http://www.soundstream.com/los/lil-wonder_amp.htm
Kicker ZX700.5 http://www.kicker.com/ZX_Amplifiers
Speakers:
Front - Rockford T2652-S : http://www.rockfordfosgate.com/products/product_details.aspx?itemid=112907 If I get them out of the US they fall inside muy $350 budget. If I go local I am thinking T1S652 http://www.rockfordfosgate.com/products/product_details.aspx?itemid=112896
Rear - Rockford T1693 6x9s. http://www.rockfordfosgate.com/products/product_details.aspx?itemid=112902
Subs - I am still trying to work out a good quality 12" pre-boxed sub that will fit in the rear of the car. Rather go with a proven boxed sub from its manufacturer, as going custom puts me back looking at talking to a shop to fabricate the box for me.
The car is an 87 Sierra Cosworth so will be getting custom pods for the front kick panels and new tray in the hatch to support the weight of the new speakers and hide the sub. I want to avoid installing the front speakers in the doors as I dont want to cut up immaculate door trims on an old car. Is that going to affect the sound I can expect from a reasonable quality front split setup?
Budget is around $1100 plus sub box + materials and bits for install.
https://www.sau.com.au/forums/topic/387834-thoughts-on-system-components/
dont do that.
use 6X9 if the hole is cut for them or dont install any speakers in back , I think the rear hatch covers had 6x9 cutouts from factory on US models. or some other weird size on the side panels in the rear ?
ford used 5x7 and 5.25 and lots of 4" during those years, crutchfield DB shows 4" front and rear but I dont think that right for rears so all speakers will need custom mounts and cutting of steel /plastic
think the doors are thin as hell and the magnets hit the glass , I only worked on one in all the years
I cant remember cosworth seirra speaker sizes in the rear .... in USA the ford /mercury XRT model cars self destructed inside and out and ended production ended quick smart less then 3 years ,they used a turbo 2.3 Pinto engine, while the euro model had a v6 2.9 ltr , now there on the collectable list , go figure ?
go rockford, good stuff , just protect the rear magnet from water on that car.or corrosion will be bad on the fords thin doors
and once again on some fords in that time frame you need a radio fit kit, to fill the gaps, back then the radio was the size of a lunchbox,, come to think of it they returned to that now.on the full electronic radios/ac etc..haha
and some fords didnt come with wires in the speaker locations back then either, so be warned you would be best to rerun some new and not link behind the dash to factory wires.
sending audio from usa , shipping can eat up the benefit of the cost, and you loose your warranty in most cases. watch radios some wont work here . Pandora on pioneer wont work either in OZ without some hacking to mask IP and creating US account for itunes.... some are dodgy dealers ,credit fraud is rapant right now in online companies during hard times in the job market , try to use paypal for safety sake
amp wise I wouldnt buy either one on a budget !!! , but if thats the choice I'd buy soundstream.
I guess if I read your whole post you asked about custom fabrication, so go splits up front, forget the rears and spend the money on amp/sub. the rear hatch lid can be upgraded easy and cheap without hacking it up , just port the bass thru the holes if it has some already
option audio makes a good choice for prefab boxes and subs
try to stear clear of the aeropro boxes or simalar , the sound can be pretty average unless you select the right driver to fit the generic box
up front you can buy prefab split setups from autobarn , and you can reuse your current door panels without cutting, just reuse the screw holes from factory speakers to hold them on. as long as the magnet doesnt hit the factory door panel your in biz. its worth buying sound baffles for the door speakers just cut them to fit , protects from water and channels the sound into door cavity , you can do some trick work on those to tweek your sound. pm me once you have the gear if you want to know how ?
Edited by Carbon 34
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
