Hey guys this is a list of the parts i have for sale.
S15 manual conversion kit $1600 ono has brand new excedy HD sprung button clutch
R33 standard alloy 16" wheels with pretty new tyres $150
17" wheels with near new tyres all lock nuts and tool included text for photos $500 CHEAP!!!
R33 manual conversion $1700 everything included came out of standard car 98,000 k no problems with box
R33 rear cradle with all suspension arms $250
R33 rear diff $150
R33 CV shafts $100
R33 rear brake setup with discs calipers drums handbrake cables $350 (2 sets available)
R33 bootlid black with spoiler good condition paint faded $100 ono
R33 doors complete with trims and everything $100 each
R33 dump pipe back exhaust 3" stainless with cat bit scratched up but hey its cheap and has a cannon $200
R33 dashboard no cluster $100
R34 dashboard no cluster $100
R33 front knuckles with hubs no brakes $50 per side
S15 seats front and back (passenger side plastic on outside damaged) $350 for the whole set GT seats not leather
S15 whiteline adjustable swaybars with links front and back $350 pair!
R34 rear diff $150
S15 rear helical diff $450
S15 bootlid no holes for spoiler pewter colour $175 I WANT A GT ONE WITH THE BIG SPOILER WILL TRADE PLUS CASH!!!
may have other stuff guys just ask me
All located in windsor NSW
Tim
0404321205
https://www.sau.com.au/forums/topic/387853-r33-s15-parts-and-wheels/
text me and i will text pictures back as it says above! i have no way of putting photos on my computer.
And if anyone needs to contact me best off texting or calling as im hardly on the computer lately!
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
